[petsc-dev] Supporting OpenCL matrix assembly
Jed Brown
jedbrown at mcs.anl.gov
Tue Sep 24 04:45:08 CDT 2013
Karl Rupp <rupp at mcs.anl.gov> writes:
>>> This can obviously be done incrementally, so storing a batch of
>>> element matrices to global memory is not a problem.
>> If you store element matrices to global memory, you're using a ton of
>> bandwidth (about 20x the size of the matrix if using P1 tets).
>> What if you do the sort/reduce thing within thread blocks, and only
>> write the reduced version to global storage?
> My primary metric for GPU kernels is memory transfers from global memory
> ('flops are free'), hence what I suggest for the assembly stage is to go
> with something CSR-like rather than COO. Pure CSR may be too expensive
> in terms of element lookup if there are several fields involved
> (particularly 3d), so one could push (column-index, value) pairs for
> each row and making the merge-by-key much cheaper than for arbitrary COO
> matrices.
I think CSR vs. COO is a second-order optimization to be considered
after the 20x redundancy has been eliminated and a synchronization
strategy has been chosen (e.g., coloring vs redundant storage and later
compression).
> This, of course, requires the knowledge of the nonzero pattern and
> couplings among elements, yet this is reasonably cheap to extract for a
> large number of problems (for example, (non)linear PDEs without
> adaptivity). Also, the nonzero pattern is rather cheap to obtain if one
> uses coloring for avoiding expensive atomic writes to global memory.
At this point, I don't mind having the nonzero pattern set ahead of time
using CPU code. It's reassembly in time-dependent problems with no
adaptivity or occasional adaptivity that I'm more concerned with.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130924/d6937e08/attachment.sig>
