[petsc-dev] Supporting OpenCL matrix assembly
Matthew Knepley
knepley at gmail.com
Mon Sep 23 17:43:45 CDT 2013
On Mon, Sep 23, 2013 at 2:46 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > Okay, here is how I understand GPU matrix assembly. The only way it
> > makes sense to me is in COO format which you may later convert. In
> > mpiaijAssemble.cu I have code that
> > - Produces COO rows
> > - Segregates them into on and off-process rows
> These users compute redundantly and set MAT_NO_OFF_PROC_ENTRIES.
Fine, we should have a flag like that.
> > - Sorts and reduces by key
> ... then insert into diagonal and off-diagonal parts of owned matrices.
Yep.
> > This can obviously be done incrementally, so storing a batch of
> > element matrices to global memory is not a problem.
> If you store element matrices to global memory, you're using a ton of
> bandwidth (about 20x the size of the matrix if using P1 tets).
> What if you do the sort/reduce thing within thread blocks, and only
> write the reduced version to global storage?
I think it should be easy, but we will have to see what is out there for
thread blocks.
Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130923/3a4380fd/attachment.html>
