[petsc-dev] build errror
    Mark F. Adams
    mfadams at lbl.gov
    Sat Sep 21 10:16:06 CDT 2013
[switched threads]
On Sep 21, 2013, at 8:45 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> What does 'gmake --version' tell you?  What happens if you rerun make?
11:07 madams/sor-residual ~/Codes/petsc$ gmake --version
GNU Make 3.82
Built for x86_64-apple-darwin12.1.0
Copyright (C) 2010  Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
> Does this work?
> $ make -f gmakefile PETSC_ARCH=arch-macosx-gnu-O
This is better.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130921/7271f171/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130921/7271f171/attachment-0001.obj>
