[petsc-dev] Push restrictions on branches
Patrick Sanan
psanan at cms.caltech.edu
Thu Sep 19 21:17:10 CDT 2013
This sounds like a great idea from the perspective of someone like me, who would only be pushing to maint/master/next in error at this point. It would also allow slightly easier access to features which are new/experimental enough to not be in next yet.
On Sep 19, 2013, at 4:35 PM, Jed Brown wrote:
> Bitbucket added support to restrict push access based on branch names
> (glob matching). For example, that would allow us to have a smaller
> group of people with access to merge to 'maint' or 'master'.
> Is this a feature we should start using in petsc.git?
> One tangible difference from the current model is that it would let give
> more people push access to named branches which then allows an
> integrator to patch up a branch for an open pull request. (When a PR
> comes from a fork instead of an in-repo branch, we can't push to their
> repository so we can't update the PR. This sometimes leads to tedious
> fine-tuning of trivial details in the PR comments.)
> Admins can see the branch list here:
> https://bitbucket.org/petsc/petsc/admin/branches
