[petsc-dev] coarse grid in gamg (for the OPTE paper)
    Jed Brown
    jedbrown at mcs.anl.gov
    Thu Sep 19 15:56:59 CDT 2013
Barry Smith <bsmith at mcs.anl.gov> writes:
>    It is essentially 3 Laplacians so I think the default null space of
>    3 constant vectors is fine. The problem is without the block
>    information presumably GAMG is using only a single constant vector
>    over all variables?  So maybe we need to construct a 3 vector null
>    space which just marks in the reduced vector from which of the 3
>    components each entry came from.
Yup, that's what I would try.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130919/f8f3a184/attachment.sig>
