[petsc-dev] 32-bits or 64-bits petsc
Jose David Bermeol jbermeol at purdue.edu
Wed Sep 18 18:39:04 CDT 2013
Hi, I've been checking how you do it in superlu_dist, and you do in the install method of SuperLUDIST.py. However I'm using intel mkl so I don't installed, so I have to decide between libmkl_intel_lp64.so and libmkl_intel_lp.so. How can I do that?? or Would I have two different packages one for mkl-32-bits and one for  mkl-64-bits?
Thanks
----- Original Message -----
To: "Jed Brown" <jedbrown at mcs.anl.gov>
Cc: "Jose David Bermeol" <jbermeol at purdue.edu>, "For users of the development version of PETSc" <petsc-dev at mcs.anl.gov>
Sent: Wednesday, September 18, 2013 2:55:54 PM
Subject: Re: [petsc-dev] 32-bits or 64-bits petsc
   Except for our calls to BLAS/LAPACK and MPI (where we have no choice) we avoid having to convert indices en mass between packages. For example when building PETSc with 32 bit indices we link against superlu_dist built for 32 bit indices and when building PETSc with 64 bit indices we link against superlu_dist built for 64 bit indices. We don't allow linking 64 bit index PETSc against both 32 bit and 64 bit superlu_dist and casting all the indices on the fly when copying them over.   I recommend you take the same route it reduces complexity of the interface and having that added flexibility doesn't buy you much IMHO.
   Barry
On Sep 18, 2013, at 1:32 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> sizeof(PetscInt) or the macro PETSC_USE_64BIT_INDICES
> On Sep 18, 2013 11:30 AM, "Jose David Bermeol" <jbermeol at purdue.edu> wrote:
> Hi, I'm coding a solver, and I'm using PetscInt for indices, the problem is that a have to do a cast to int or long long int to pass the information to my external package, is there a variable that says which kind of indices(int or long long int) I'm using?
> Thanks
