[petsc-dev] PETSc-3.4 PR open at https://github.com/Homebrew/homebrew-science/pull/343
Aron Ahmadia
aron at ahmadia.net
Wed Sep 18 17:34:23 CDT 2013
Prof. Orban has generously contributed a PR to get PETSc-3.4 going on
homebrew at the following link:
It's currently set up to use dynamic libraries, a homebrew-installed
Fortran and a homebrew-installed MPI, with an optional dependency on X11
(used if available).
It would probably not be too much more work to make the Fortran dependency
optional, or add any other packages that are frequently used with PETSc.
Any thoughts from the developers?
Cheers,
Aron
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130918/83e7dc6c/attachment.html>
