[petsc-dev] get moving on gnu make version of PETSc compiler
Jed Brown
jedbrown at mcs.anl.gov
Tue Sep 17 14:14:35 CDT 2013
Satish Balay <balay at mcs.anl.gov> writes:
> Adding in the following [partial] dependencies gets the build working
> for me. But I'm not sure what the correct way to add this would be..
Was the problem reproducible? I never encountered it.
Can we determine in the makefile whether MPIUNI is being used? We could
generate the proper dependencies in gmakegen.py, but if we're not
checking the source to pick up module dependencies, I'd rather use the
hack in gmakefile.
> Satish
> balay at petsc^/sandbox/balay/petsc.clone((4920dd4...)) $ git diff
> diff --git a/gmakefile b/gmakefile
> index bd3ef2e..543c229 100644
> --- a/gmakefile
> +++ b/gmakefile
> @@ -134,6 +134,9 @@ $(OBJDIR)/%.o : %.cu | $$(@D)/.DIR
> $(PETSC_COMPILE.cu) $< -o $@ # Compile first so that if there is an error, it comes from a normal compile
> @$(PETSC_GENDEPS.cu) $< -o $(@:%.o=%.d) # Generate the dependencies for later
> +$(OBJDIR)/src/snes/f90-mod/petscsnesmod.o:$(OBJDIR)/src/ksp/f90-mod/petsckspmod.o
> +$(OBJDIR)/src/ts/f90-mod/petsctsmod.o:$(OBJDIR)/src/snes/f90-mod/petscsnesmod.o
> $(OBJDIR)/%.o : %.F | $$(@D)/.DIR
> ifeq ($(FC_MODULE_OUTPUT_FLAG),)
> cd $(PETSC_ARCH)/include && $(FC) -c $(FC_FLAGS) $(FFLAGS) $(FCPPFLAGS) $(FC_DEPFLAGS) ../../$< -o ../../$@
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130917/e1e47fa7/attachment.sig>
