[petsc-dev] master breaking with gmake
    Barry Smith
    bsmith at mcs.anl.gov
    Tue Sep 17 14:01:28 CDT 2013
   Hmm, now runs ok. Sorry false alarm I must have done something wrong.
    Barry
On Sep 17, 2013, at 1:52 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Also are you doing 'make cmake' and not 'make all'?
> [because 'make all' should default to gmake build and not cmake - and internally both use 'make' for parallel builds]
> Satish
> On Tue, 17 Sep 2013, Satish Balay wrote:
>> Mark also had this issue.
>> what do you have for
>> 'which gmake'
>> And why is gmake broken on Mac :(
>> Currently configure option is --with-make= --download-make etc..
>> Perhaps we need to add alias for 'make=gnumake' or something..
>> /usr/bin/make is a valid gmake  on Mac - so --with-make=make would work.
>> I changed the cofigure deault to look for 'gmake' first before 'make'
>> [because gmake is more likely to be gnumake than make on some
>> machines]
>> Satish
>> On Tue, 17 Sep 2013, Barry Smith wrote:
>>>  No --download-gmake ? or --download-gnumake?   This seems wrong.
>>>   Barry
>>> On Sep 17, 2013, at 1:43 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>> ~/Src/petsc  barry/fix-petscobjectsetstate $ gmake --version
>>>> GNU Make 3.82
>>>> Built for x86_64-apple-darwin10.8.0
>>>> Copyright (C) 2010  Free Software Foundation, Inc.
>>>> License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
>>>> This is free software: you are free to change and redistribute it.
>>>> There is NO WARRANTY, to the extent permitted by law.
>>>> [ 15%] Building C object CMakeFiles/petsc.dir/src/sys/classes/draw/utils/ftn-custom/zaxisf.c.o
>>>> [ 15%] [ 15%] Building C object CMakeFiles/petsc.dir/src/sys/classes/draw/utils/ftn-custom/zzoomf.c.o
>>>> Building C object CMakeFiles/petsc.dir/src/sys/classes/random/interface/ftn-auto/randomcf.c.o
>>>> [ 15%] Building C object CMakeFiles/petsc.dir/src/sys/classes/random/interface/ftn-auto/randomf.c.o
>>>> [ 15%] [ 15%] Building C object CMakeFiles/petsc.dir/src/sys/classes/random/interface/ftn-custom/zrandomf.c.o
>>>> Building Fortran object CMakeFiles/petsc.dir/src/sys/fsrc/somefort.F.o
>>>> [ 15%] Building C object CMakeFiles/petsc.dir/src/sys/time/ftn-auto/cputimef.c.o
>>>> [ 15%] Building C object CMakeFiles/petsc.dir/src/sys/time/ftn-custom/zptimef.c.o
>>>> [ 16%] [ 16%] Building C object CMakeFiles/petsc.dir/src/sys/threadcomm/impls/pthread/tcpthread.c.o
>>>> Building C object CMakeFiles/petsc.dir/src/sys/threadcomm/impls/pthread/tclockfree.c.o
>>>> [ 16%] [ 16%] Building C object CMakeFiles/petsc.dir/src/vec/is/utils/ftn-auto/isltogf.c.o
>>>> Building C object CMakeFiles/petsc.dir/src/vec/is/utils/ftn-auto/vsectionisf.c.o
>>>> [ 16%] Building C object CMakeFiles/petsc.dir/src/vec/is/is/impls/stride/ftn-auto/stridef.c.o
>>>> gmake[3]: *** read jobs pipe: No such file or directory.  Stop.
>>>> gmake[3]: *** Waiting for unfinished jobs....
>>>> [ 16%] Building C object CMakeFiles/petsc.dir/src/vec/is/is/impls/block/ftn-auto/blockf.c.o
>>>> gmake[2]: *** [CMakeFiles/petsc.dir/all] Broken pipe: 13
>>>> gmake[1]: *** [all] Error 2
>>>> gmake[1]: INTERNAL: Exiting with 1 jobserver tokens available; should be 7!
>>>> make: *** [ccmake] Error 2
>>>> Compilation exited abnormally with code 2 at Tue Sep 17 13:41:43
