[petsc-dev] bfort broken with plex?
Jed Brown
jedbrown at mcs.anl.gov
Thu Sep 12 16:26:22 CDT 2013
Satish Balay <balay at mcs.anl.gov> writes:
> Jed,
> The sowing update is primarily required by
> knepley/feature-plex-generic-distribute Hower I branched
> 'balay/update-sowing' off master - and merged to next.
> Should I have directly commited to
> knepley/feature-plex-generic-distribute?
> Should I now merge balay/update-sowing into
> There is one more fix required here: add MPI_Type_f2c() to mpiuni. And
> this is dependent on knepley/feature-plex-generic-distribute +
> balay/update-sowing
> Trying to figure out where to commit this..
> perhaps merge [or rebase] balay/update-sowing to
> knepley/feature-plex-generic-distribute - and the commit directly to
Add the MPIUNI support to 'balay/update-sowing', then merge it into
'knepley/feature-plex-generic-distribute'. Don't rebase because we
already have one copy of that commit in 'next'.
'balay/update-sowing' makes sense without
'knepley/feature-plex-generic-distribute' so it was right to make it its
own branch.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130912/b4008d4a/attachment.sig>
