[petsc-dev] get moving on gnu make version of PETSc compiler
Jed Brown
jedbrown at mcs.anl.gov
Wed Sep 11 19:15:32 CDT 2013
"Nystrom, William D" <wdn at lanl.gov> writes:
> From the perspective of PETSc users, what does this mean?
You won't have CMake crash on you with exit code 256 because it won't be
used. The "cmakegen" step does not need to happen. Builds might be
ever so slightly faster.
> I have a limited understanding of the PETSc build system right now but
> am aware that there is the python component, a cmake component and a
> legacy component. There may be other aspects I am not aware of. Will
> there still be the python component?
Yes, Python is used for configure and it is used to decide which files
need to be part of the library.
> Is the gmake system replacing cmake?
I expect to maintain the (generated) CMake build indefinitely so that
people that like IDEs can use it to generate project files. If it turns
out that nobody uses that feature, we could remove it.
> Will parallel builds be more robust?
It should parallelize a bit better than CMake (which has some
artificially strict rules).
> Will the current "all-legacy" target go away or will it be replaced by
> whatever gmake is replacing?
It'll probably stick around for a little while so we can fall back to
it. I hope to remove it once all the bugs are worked out. Removing the
legacy build will let us simplify the library significantly and make it
much less error-prone to move source files around. The documentation
system still needs the legacy build at the moment, so that will have to
be updated before we can remove it.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130911/2aaa9c4f/attachment.sig>
