[petsc-dev] Extending Petsc
Jose David Bermeol
jbermeol at purdue.edu
Wed Sep 11 16:21:19 CDT 2013
Hi, right now I'm working in add a new solver for seq aij matrices. What I have until this point are the following files inside the folder aij/seq/:
- package/ folder with my code
- package.c a initial implementation of the solver.
- makefile is basically a copy of the make file in superlu, but using the name of my package instead of "superlu".
Also I add to petscmat.h my solver type. Then I run ./configure with the flag --with-package-dir=PATH_TO_PACKAGE. The thing is that when I'm compiling the variable PETSC_HAVE_PACKAGE doesn't show up, I guess that means the variable is 0 or something else happens, and my code is not going to be compile. So if you could give some ideas of why Petsc doesn't compile my code.
Thanks
