[petsc-dev] PetscSection
Matthew Knepley
knepley at gmail.com
Wed Sep 11 03:47:12 CDT 2013
On Tue, Sep 10, 2013 at 11:25 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Sep 10, 2013, at 8:55 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> > Matthew Knepley <knepley at gmail.com> writes:
> >>> PetscSF cannot currently scatter individual bytes (4 bytes minimum),
> and
> >>> even if it could, it's a horribly inefficient representation (4 or 8
> >>> bytes of metadata for each byte of payload). The quick fix at that
> >>> moment was to send in units of size PetscInt (the struct was always
> >>> going to be divisible by that size).
> Since when are PETSc people interested in quick fixes, we are only
> concerned with doing things right; quick fixes lead to bad code and bad
> ideas.
> >> The way I understand it, he never had a single MPI_BYTE, but always a
> bunch.
> >> Shouldn't that packing handle that case?
> > In DMPlexDistributeData, your fieldSF is blown up so that every unit has
> > its own metadata (rank, offset). That's a terrible mechanism for moving
> > structs with hundreds of bytes.
> > I would rather not make PetscSF deal with fully-heterogeneous data
> > (where each node can have a different size) because it makes indexing a
> > nightmare (you need a PetscSection or similar just to get in the door; I
> > don't want PetscSF to depend on PetscSection).
> Having PetscSF depend on PetscSection would be insane (after all
> PetscSection has information about constrained variables and other silly
> nonsense) but having PetscSF depend on XX makes perfect sense.
> A review:
> (current situation; with unimportant stuff removed)
> + sf - star forest
> . nroots - number of root vertices on the current process (these are
> possible targets for other process to attach leaves)
> . nleaves - number of leaf vertices on the current process, each of these
> references a root on any process
> . ilocal - locations of leaves in leafdata buffers, pass NULL for
> contiguous storage
> . iremote - remote locations of root vertices for each leaf on the
> current process
> PetscSFSetGraph(PetscSF sf,PetscInt nroots,PetscInt nleaves,PetscInt
> *ilocal,,PetscSFNode *iremote,)
> typedef struct {
> PetscInt rank; /* Rank of owner */ (why is this not
> PetscMPIInt?)
> PetscInt index; /* Index of node on rank */
> } PetscSFNode;
> abstractly nleaves, ilocal are the indices (into an array) you are
> copying too; iremote are the indices (into an array) you are copying from
> Now if PETSc had an abstract concept of indexing (funny no one ever put
> that in PETSc decades ago) it would look like
> PetscSFSetGraph(PetscSF sf,PetscInt nroots, toIndices , fromIndices)
> but wait; PETSc does have have an abstraction for indexing (into regular
> arrays) called IS, come to think of it, PETSc has another abstraction for
> indexing (into arrays with different sized items) called XX. Actually
> thinking a tiny bit more one realizes that there is a third: PetscSFNode is
> a way of indexing (into regular arrays) on a bunch of different processes.
> We come up with a couple more related, but inconsistent syntaxes for
> indexing, we'll have code has good as Trilinos.
> So let's fix this up! One abstraction for indexing that handles both
> regular arrays, arrays with different size items and both kinds of arrays
> on a bunch of different processes; with simple enough syntax so it can be
> used whenever indexing is needed including passing to PetscSF! (We can
> ignore the need for MPI datatypes in communication for now).
> Concrete examples to demonstrate this need not be so difficult. A
> completely general set of indices for this situation could be handled by
> typedef struct {
> PetscInt nindices;
> PetscMPIInt *ranks;
> PetscInt *offsets;
> PetscInt *sizes;
> } XXData; Hardly more than PetscSFNode. Or could be handled as an array
> of structs.
> special cases would include:
> all on one process so ranks is not needed
> all items the same size so sizes not needed
> contiquous memory (or strided) so offsets not needed
> If we decided not to go with an abstract object but instead just a
> concrete data structure that could handle all cases it could look something
> like
> typedef struct {
> PetscInt nindices;
> PetscMPIInt *ranks;
> PetscInt *offsets;
> PetscInt *sizes;
> PetscInt chunksize,strideoffset;
> } XXData;
> For completeness I note with IS (for example in VecScatter creating with
> parallel vectors) we don't use rank,offset notation we use global offset ==
> rstart[rank] + offset but that is something I'm sure we can deal with.
> QED
> Comments?
This sounds like a good idea. So
- we always store indices in blocks (get rid of regular IS)
- we can optimize for strided (get rid of strided IS)
- they can be local or nonlocal (get rid of PetscSFNode)
Right now, I have a GlobalSection, which uses XX but puts in different
values. It has negative offsets
and sizes for nonlocal indices. Now I could just allocate the ranks array
and check for different rank
rather than negative offset.
This would increase the size of GlobalSection, but then I could shared
indices with PetscSF, so overall
we could have a decrease. So it seems like PetscSection and PetscSF could
share a substantial
amount of code if we go to a common data structure.
I believe all this is orthogonal to the packing issue, which I think can be
done before we unify indices.
In PetscSectionCreateFieldSF() I choose a granularity for communication. It
would be easy to check
for a common multiple of sizes here, and only check if MPI_Type is small.
This is likely to be what we
want to do in general, even creating our own packed types for
communication. I will try and code it up.
Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130911/bc5b6ec4/attachment.html>
