[petsc-dev] PetscSection
Matthew Knepley
knepley at gmail.com
Tue Sep 10 20:47:30 CDT 2013
On Tue, Sep 10, 2013 at 8:43 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> >> I was unclear. The offset value should be in bytes from the beginning
> >> of the array, currently it is in ints from the beginning of the array.
> Ints
> >> is just plan confusing, Shri has to have this strange size sizeof(his
> >> struct)/sizeof(PetscInt) to indicate how big his chunk is.
> > No, its has nothing to do with Int. Where did this come from? In fact, I
> > use it all the time to mean Scalar offsets. It is
> > interpreter by the creator of the Section. I told him to put in bytes for
> > the sizes. Then you do not need any of that crap.
> PetscSF cannot currently scatter individual bytes (4 bytes minimum), and
> even if it could, it's a horribly inefficient representation (4 or 8
> bytes of metadata for each byte of payload). The quick fix at that
> moment was to send in units of size PetscInt (the struct was always
> going to be divisible by that size).
The way I understand it, he never had a single MPI_BYTE, but always a bunch.
Shouldn't that packing handle that case?
Matt
> After looking at code with him yesterday, it looks like he just needs a
> separate Section for each of four different types of node. Within each
> node type, the sizes are homogeneous (though there may be multiple
> structs at a vertex of the graph). In that case, he can make an
> MPI_Datatype for sizeof(struct Node) bytes and communicate those.
> PetscSF should do fine with that.
> The indexing still needs the size of a unit, but there would be no stray
> sizeof(Int) running around.
> In that discussion, we also concluded that having the user add code to
> one big struct definition was a terrible approach and we should
> dynamically build structures by registration. I pointed him to the
> monitor infrastructure in Parmod (like in TS ex11).
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130910/ea2aa814/attachment.html>
