[petsc-dev] PetscSection
    Jed Brown
    jedbrown at mcs.anl.gov
    Tue Sep 10 20:47:16 CDT 2013
Matthew Knepley <knepley at gmail.com> writes:
> I wish the guy who write PetscSF believed in types smaller than int. Just
> because they are small, does not mean they
> cannot achieve great things. MPI_BYTE is the Little Type That Could.
You have a (rank, offset) per unit.  If unit is one byte, then you have
inflated the metadata by at least 8x (16x when 64-bit-indices).  That
is, you're using 8 bytes of metadata to move each byte of payload.
That's silly; we need a different model.
It looks like Shri would be just fine with 4 separate sections, each
with homogeneous-sized units.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130910/18eadec2/attachment.sig>
