[petsc-dev] PetscSection
    Matthew Knepley
    knepley at gmail.com
    Tue Sep 10 18:57:04 CDT 2013
On Tue, Sep 10, 2013 at 6:53 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Sep 10, 2013, at 6:11 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > On Tue, Sep 10, 2013 at 5:14 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >    We had this discussion last November. Now that DMPlex has further
> matured and is likely to play a big role in some major applications I'd
> like to revisit the issue and see if PetscSection can be refactored to be
> easier to understand and more useful and more "compatible" with how DMPlex
> is developing.
> >     PetscSection seems to have two distinct roles:
> >   Role 1   (I'll call this object XX)  Provides a way of indexing into
> an array of "items" where different items can be of different sizes and
> there can be spaces in the memory between items.
> >   struct _n_PetscUniformSection atlasLayout;  /* Layout for the atlas */
> >   PetscInt                     *atlasDof;     /* Describes layout of
> storage, point --> # of values */
> >   PetscInt                     *atlasOff;     /* Describes layout of
> storage, point --> offset into storage */
> >   PetscInt                      maxDof;       /* Maximum dof on any
> point */
> >   PetscBool                     setup;
> > So if we have a regular C array pointer to type int, double etc we do
>  addr = array + p == &array[p] to get the address of the pth item (where p
> may only be valid between pstart and pend.) With PetscSection instead one
> would do XXGetOffset(xx,p,&offset);  addr = (type*) (array + offset); while
> XXGetDOF(xx,p,dof); gives you the "size" of the memory at location addr.
> >     For historical reasons the offsets are in terms of int* instead of
> char*;  (this should be fixed)
> > I do not understand this. The offsets are integers, and I think they
> should be.
>   I was unclear.  The offset value should be in bytes from the beginning
> of the array, currently it is in ints from the beginning of the array. Ints
> is just plan confusing, Shri has to have this strange size sizeof(his
> struct)/sizeof(PetscInt) to indicate how big his chunk is.
No, its has nothing to do with Int. Where did this come from? In fact, I
use it all the time to mean Scalar offsets. It is
interpreter by the creator of the Section. I told him to put in bytes for
the sizes. Then you do not need any of that crap.
> >     This is a useful thing but in itself not a killer app.  What makes
> it a killer app are
> >  DMPlexDistributeField(DM dm, PetscSF pointSF, XX originalSection, Vec
> originalVec, XX newSection, Vec newVec)
> >  DMPlexDistributeData(DM dm, PetscSF pointSF, XX originalSection,
> MPI_Datatype datatype, void *originalData, XX newSection, void **newData)
> >     Note that these do not actually even use the DM (the code should be
> fixed by moving it out of DMPlex into the "lower level" code.) Note also
> these really create newSection internally (the code should be fixed by
> making these take PetscSection *newSection).
> > I can move them over to vsectionis.c. I do not agree that the signature
> should change. I thought we were going to
> > the VecLoad() paradigm where an empty object comes in.
> >     What this means is that if I have a set of "points" distributed
> across MPI processes and for each point a "bunch of data" (in an "array"
> offsetted by a XX) and I redistribute the points across MPI processes
> including adding ghost points then I can redistribute all the "bunch of
> data" (including that needed for ghost points) trivially and conveniently
> access it using the newSection.
> > Yep, this should be very useful, an extension of the very useful
> VecScatter.
> >    Role 2 (I'll call this object CC)  Provides a container that tells
> you which parts of "bunches of data" in an array or Vec are associated with
> different "physical simulation fields" and are possibly constrained (for
> example by boundary conditions). Uses XX to indicate each field etc.
> >   PetscSection                  bc;           /* Describes constraints,
> point --> # local dofs which are constrained */
> >   PetscInt                     *bcIndices;    /* Local indices for
> constrained dofs */
> >   PetscInt                      numFields;    /* The number of fields
> making up the degrees of freedom */
> >   const char                  **fieldNames;   /* The field names */
> >   PetscInt                     *numFieldComponents; /* The number of
> components in each field */
> >   PetscSection                 *field;        /* A section describing
> the layout and constraints for each field */
> >    Suggestion:
> >         We split PetscSection into XX and CC reorganize and clean them
> up.
> > Okay. The reason I did it this way was that any FEM code is going to
> need CC, and it needs to contain XX, so
> > I just made XX the container. We can make CC the container and have the
> split that you want. It makes sense.
> >    Relationship of XX to IS.
> >         An IS defines a subset of entries in a Vec or possibly in an
> array of type int. Generally individual entries in an IS do not have
> particular meaning relative to other entries. That is one does not iterate
> over entries in an IS, one just uses the IS to get a new Vec and then does
> whatever on that Vec.
> >        An XX is something you often iterate over, for example
> >     for (p = pStart; p < pEnd; ++p) {
> >       PetscInt dof, off, s;
> >       ierr = PetscSectionGetDof(mesh->supportSection, p,
> &dof);CHKERRQ(ierr);
> >       ierr = PetscSectionGetOffset(mesh->supportSection, p,
> &off);CHKERRQ(ierr);
> >       do something
> > that is you get a single entry of XX and do something with it (though
> you can also get a bunch of entries and do something on the whole bunch).
> > We do have these kind of offset structures in PETSc (MatAIJ), but they
> are hardcoded in.
> >    Question:
> >     Is XX a powerful and useful thing? Do we have the correct API for
> it? Can it be used for other purposes?
> > I think its all yes.
> >     Can it be made more powerful: for example the "chunk" that it gives
> you is always a contiqous set of bytes in the "array". Would be be better
> off with a YY object that allowed them to be non-contiquous? Or should YY
> be a higher level object implemented with XX?
> > Let me take this statement apart. So for any point p, the Section gives
> you back (offset, dof), so that you can use it to refer to
> >    array[offset]...array[offset+dof]
> > which is the "chunk" that Barry is talking about. It is contiguous by
> design. That is how we achieve compression in the representation. I claim
> you
> > can get the YY object with two XX objects. The first XX object says how
> many "points" in the second XX correspond to each chunk. Each one of
> > the subchunks in the second XX is contiguous but they create a
> non-contiguous chunk for the first XX. In general, any non-contiguous thing
> is
> > represented by a set of contiguous things. This is not a good
> representation is you mostly have scatter, scalar data. However, I think we
> mostly have
> > scattered blocks of data.
>    Is this second thing, built on two XX worthing of its own abstraction?
> For example when I way give me the coordinates of the nodes of a triangular
> in a mesh?
I am not sure I understand what you want here. I don't think this YY thing
is all that useful since I can't see the generality.
   Matt
> >    Looking for a vigorous discussion and then code that I can better
> understand.
> > Me too, so "Jed is probably all wrong about this" :)
> >    Matt
> >    Barry
> > On Nov 8, 2012, at 10:18 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> > > This is inevitable, but may still not resolve anything. I'm sure Matt
> will correct whatever below is incorrect. The main question is whether to
> promote PetscSection to a PetscObject or to hide/replace it with something
> else.
> > > So PetscSection is an unloved (by most) beastie that is sort of
> intermediate between an IS and a DM. Its core functionality is to provide
> indirect indexing with variable block sizes. It consists of two parts, the
> first of which is less than a PetscLayout.
> > > struct _n_PetscUniformSection {
> > >   MPI_Comm comm;
> > >   PetscInt pStart, pEnd; /* The chart: all points are contained in
> [pStart, pEnd) */
> > >   PetscInt numDof;       /* Describes layout of storage, point -->
> (constant # of values, (p - pStart)*constant # of values) */
> > > numDof is always 1 and PetscUniformSection is never referenced from a
> *.c file so this is really just a range of valid "point" values
> [pStart...pEnd).
> > > struct _n_PetscSection {
> > > ^^ These two fields are the essential part. Each index in
> [pStart,pEnd) is mapped to a block of size atlasDof[p-pStart] located at
> atlasOff[p-pStart]. Matt composes these indirect maps for storing meshes
> and other indexing tasks. This "unsorted offset mapping" is indeed used
> frequently in PETSc, though outside of Matt's code, it's just raw arrays.
> > > User's primarily encounter PetscSection when accessing unstructured
> meshes or any time the number of degrees of freedom or locations of each
> "point" (topological entity in the mesh) is not uniform. DMs do a similar
> thing (provide more logical access to a Vec), but DMDAVecGetArray() is of
> course only natural for a structured grid.
> > > At the user interface level, provided the user doesn't need low-level
> access to topology, I think there are three possibilities.
> > > 1. To compute a residual at a cell, user does
> > > VecGetArray(F,&f); // normal access to the Vec
> > > DMComplexGetHeightStratum(dm,0,&cstart,&cend); // "height 0" is like
> codimension 0 with respect to the maximum topological dimension. Matt and I
> have have a philosophical debate over whether users prefer to think in
> "strata" (that can skip dimensions, so "height 1" could be a face, an edge,
> or a vertex depending on what is stored in the mesh) or in "topological
> dimensions" (where codim=1 is a "face" for a 3D mesh and an edge for a 2D
> mesh).
> > > DMGetDefaultSection(dm,§ion);
> > > for (c=cstart; c<cend; c++) {
> > >   PetscInt off;
> > >   PetscSectionGetOffset(section,c,&off);
> > >   f[off+0] = residual of first equation at this cell;
> > >   f[off+1] = residual of second equation;
> > >   // brushing under the rug how we access neighbor values
> > > The above is basically the current model. Matt has
> DMComplexGet/SetClosure(), but that interface carries a sleeper reference
> to the Vec's array and he says he plans to remove it.
> > > 2. Add DMComplex-specific access routines so the user does not need to
> see the PetscSection. Presumably this would be something like
> > > DMComplexGetPointOffset(dm,c,&offset); // offset into owned part of
> global vector?
> > > DMComplexGetPointOffsetLocal(dm,c,&loffset); // offset into local
> vector
> > > 3. Access cursors (another object).
> > > DMComplexGetCursors(dm,Vec U,3,&uface,&ucellL,&ucellR);
> > > // similar for F
> > > DMComplexGetHeightStratum(dm,1,&fstart,&fend);
> > > for (f=fstart; f<fend; f++) {
> > >   const PetscInt *c;
> > >   const PetscScalar *uL,*uR,*uF;
> > >   DMComplexGetSupport(dm,f,&c); // left and right cells
> > >   DMCursorGetValues(uface,f,&uF); // only used for staggered/mixed
> discretization
> > >   DMCursorGetValues(ucellL,c[0],&uL);
> > >   DMCursorGetValues(ucellR,c[1],&uR);
> > >   // Solve Riemann problem with "face" values uF[] (if using a
> staggered discretization), uL[], and uR[].
> > >   DMCursorRestoreValues(uface,f,&uF); // ...
> > > The "advantage" of the cursors here is that DMComplex doesn't need to
> hold the context manager itself (perhaps for multiple threads), the code
> dealing with the number of concurrent accesses is outside the inner loop,
> and the implementations of these accessors are trivial (offset). I think
> it's still not compelling for the sketched discretization above, but
> consider also FEM methods where we need to access all degrees of freedom on
> the closure of an element. The following packs a buffer with the closure
> (because it's not contiguous in memory).
> > >   DMCursorGetClosure(cell,c[0],&uc);
> > > 4. Alternative suggestions?
> > > I'm so sick of the name DMComplex. Let's just rename to DMPlex. It's
> shorter and doesn't have a double-meaning. Or pretty much any other name
> but "Complex".
> > > For completeness, the last bit of _n_PetscSection:
> point */
> constraints, point --> # local dofs which are constrained */
> constrained dofs */
> > > These BC fields are for doing masked updates, such as
> VecSetValuesSection() which ignores constrained dofs.
> > >   PetscInt                      refcnt;       /* Vecs obtained with
> VecDuplicate() and from MatGetVecs() reuse map of input object */
> > >   PetscBool                     setup;
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130910/fd6b35f8/attachment.html>
