[petsc-dev] non portable code in next, why? realpath and system
Tue Sep 10 07:58:43 CDT 2013
Jed Brown <jedbrown at mcs.anl.gov> writes:
>> 1)  realpath doesn't exist on Apple make alltests gives ugly shit below
> Huh, I thought it was POSIX, but it looks like that's only the libc
> function.  Will fix.
This has been fixed in 'next', but the new test code is a bit more
complicated.  It has to manually take the path apart because realpath(3)
requires the path to exist while realpath(1) only needs the implied
containing directory to exist.  An alternative would have been to call
out to python, but I don't want to depend on it existing on the node
running tests.
https://bitbucket.org/petsc/petsc/commits/e2e8085b812c6e1b8a258f61ab280be1790bea9d
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130910/6423f66f/attachment.sig>
