[petsc-dev] different compiler behavior in make libfast and make all
Chetan Jhurani
chetan.jhurani at gmail.com
Mon Sep 9 22:28:59 CDT 2013
> Have you reported the bug to Microsoft?
Not yet, but I will after making a reasonable translation
unit.
After my last mail I realized that setting cl.exe affinity
to one core was no guarantee to make it run one thread.
And it did not. So I just booted after setting 1 core
in bios and no hyperthreading. Task manager and env
variables show that my system has one core and not 4. But cl.exe
still launches 4 worker threads on a single core for a single
file and again fails in 10% of cases.
Anyway, the point is that it has all the signs of being a
multi-threaded bug seemingly without any way of turning off
threading in the compiler. As far as I could see, cl.exe in the
previous version, VS 2010, does not use multiple worker threads
and so older versions work fine.
> > The error happened in roughly 10% of 100 consecutive
> > compilations of the file. Happens with -O1 and -O2.
> > But no error when optimization is off. Although I
> > have not gone so far as having a minimal workaround, two
> > possible solutions are to have optimization off for select
> > functions in a few files using #pragma or just turn off
> > optimizations for three directories where such errors
> > happened -
> > src/mat/impls/sbaij/seq/sbstream
> > src/mat/impls/baij/seq
> These directories have some of the kernels that stand the most chance of
> benefiting from optimization. If you break the files up, do the errors
> go away?
I agree with the optimization need, especially for people using complex
scalar.
But I have not tried splitting files. Even if errors do go away,
they might only be reduced statistically, which does not lead to a
reliable solution. For Microsoft, it might be easier to fix the
compiler bug using the existing file with more functions that
fails 10% of time rather than a file with fewer functions that fails
very rarely and making the bug(s) harder to reproduce.
Chetan
