[petsc-dev] sor smoothers
Jed Brown
jedbrown at mcs.anl.gov
Mon Sep 9 14:52:30 CDT 2013
Satish Balay <balay at mcs.anl.gov> writes:
> I think the current approach is simpler..
> if !defined(PETSC_HAVE_STDINT_H) && defined(PETSC_HAVE___INT64)
> typedef __int64 .....
The PETSC_SIZEOF_ macros could be removed. (We can probably remove most
or all of them now, but most of their uses would go away.) Not a big
issue, but fewer tests in configure and fewer preprocessor clauses in
PETSc.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130909/02c9b4a6/attachment.sig>
