[petsc-dev] writing to petsc-hg
Jed Brown
jedbrown at mcs.anl.gov
Mon Sep 9 13:53:55 CDT 2013
Barry Smith <bsmith at mcs.anl.gov> writes:
>>> FWIW, just want to correct an occasional typo.
>> push is to git repo [I can enable access] - or you can send us the patches [with 'hg diff']
> NO. We want you to write directly, no emailing patches!
He can fork petsc-hg and send pull requests to petsc-hg. Since petsc-hg
does not have a 'next', I would accept the patch by pulling it via
hg-git and merging it on the git side. (Nobody else needs to care about
this part.) It'll find its way into petsc-hg only after it goes to
'master'. Or Victor can just use Git.
If you know how to email patches without flubbing the formatting, I
think that's perfectly fine. Using git send-email or the Hg patchbomb
extension is fewer steps than forking the repository and it's plenty
easy to apply (I apply patch series directly from my email client).
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130909/3af12b51/attachment.sig>
