[petsc-dev] Questions about Petsc
Matthew Knepley
knepley at gmail.com
Fri Sep 6 14:33:13 CDT 2013
On Fri, Sep 6, 2013 at 2:26 PM, Peter Brune <prbrune at gmail.com> wrote:
> On Fri, Sep 6, 2013 at 1:53 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Fri, Sep 6, 2013 at 1:33 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>> Please send these questions to petsc-dev (Cc'd now) or petsc-users so
>>> that others can comment.
>>> Lulu Liu <lulu.liu at kaust.edu.sa> writes:
>>> > Hi,
>>> > I want to implement ASPIN-like ideas, but based on field splitting. You
>>> > could find the details in PDF file.
>>> You are proposing left-preconditioned nonlinear additive fieldsplit.
>>> This is a sensible algorithm that we have discussed before. The only
>>> part that needs to be implemented is the fieldsplit solve: separation of
>>> G and H, then solving each separately.
>>> Unfortunately, I think it's kinda tricky to come up with a generally
>>> useful interface. In particular, many applications cannot partition the
>>> variables like you have done, meaning that the preconditioner is
>>> becomes: change variables, solve in other bases, then change back. At
>>> this point, I would recommend implementing the solve with \hat F using
>>> SNESShell.
>> Did we throw away the SNES 'multiblock' code? It was supposed to do this.
> Multiblock never actually ran and therefore it has been removed from
> compilation for some time. The code is still sitting there, though. We've
> (Jed and I) been discussing how to put this together for some time and we
> haven't settled on a model of prying apart the fields and field
> residual/Jacobian assembly in such a way that makes this easy enough for
> users to futz around with. We could easily do something akin to what we do
> with (N)ASM and have hooks that spirit the whole solution to where the
> evaluation needs it.
At one point it ran :) So I think the way to do this is to only activate it
if the user has a DM+PetscSection. Then we have enough information
to take apart the nonlinear residual evaluation. In fact,
DMPlexComputeResidual() does it field-by-field right now.
Matt
> So, what do you do? Do you do whole-system residual evaluation followed
> by restriction to the subsystem? Do you require the user to give you a
> number of subproblems living on potentially different discretizations and
> ways of gluing them together? These things need to be decided.
> ASPIN-like things with this would require having the outer solver know how
> to pull apart the inner solver and get at its tasty, tasty fieldsplit
> Jacobians. It would be a pretty easy extension of the preexisting ASPIN
> stuff.
> - Peter
> Matt
>>> > My questions:
>>> > I have a nonlinear system including two equations. In my
>>> implementation, I
>>> > need to solve each equation separately, also I need to solve the
>>> coupled
>>> > system. I feel confused about ordering:
>>> > I know the unknowns are ordered as [p1,s1,p2,s2,p3,s3,......] in PETSc,
>>> > however, it seems that I need the variables like [p1,p2,p3,...
>>> s1,s2,s3,...]
>>> No, just use a strided IS to describe each set of variables. You can
>>> VecScatter from the packed/monolithic global vector to the split space.
>>> > Is there any example to do the similar things in PETSc?
>>> > Do you have any ideas to implement the algorithm easier?
>>> > How to quickly extract [p1,p2,...p_{N}] or [s1,s2,....] from
>>> > [p1,p2,....s1,s2,s3,...] ?
>>> > How to quickly get the composed [p1,p2,...s1,s2,....] if I have
>>> [p1,p2,...]
>>> > and [s1,s2,..]?
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130906/647b60b3/attachment.html>
