[petsc-dev] PetscIntialize docs
Satish Balay
balay at mcs.anl.gov
Thu Sep 5 14:39:20 CDT 2013
On Thu, 5 Sep 2013, Mark F. Adams wrote:
> >> On Sep 5, 2013, at 12:46 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> >>>>> I wanted to not have files get checked and added -skip_petscrc to
> >>>>> the command line but this was not sufficient. I needed to change
> >>>>> the code to use NULL (or I told my user to do so).
> >>> Was 'useroptfile' causing some problem - or is it that you wanted to
> >>> avoid it for some other reason?
> >> This was the problem with Mira that we went through with Jeff H. last week. Where getting the home directory was failing occasionally and hanging the system. So I was told to use -skip_petscrc on the command line, which failed to get the code to skip the (user) RC file.
> > But did the code hang or crash?
> No, we have been running small problems, for debugging, and small problems to not trigger this bug.
Just to clarify - the buggy 'getpwuid(getuid())' on bgq induced a
deadlock in MPI messaging - which -skip_petscrc avoids. That doesn't
imply 'avoid loading all petscopt/usropt files'.
My fix [with the assumption of 'getpwuid(getuid())' can ocassionally
return null] continues to load the rc files - provided the path can be
resolved.
Jed subsequent change [hasn't merged to maint yet] - is to avoid
getpwuid() - to avoid cases where it can SEGV. [i.e HOME/.petscrc will
never get resolved on bgq]
I haven't seen SEGVs on bgq - but they did occur in preproduction bgq
software stack.
Satish
> > Satish
> >> In looking at the code I realized that you need to not give PetscInitialize() an RC file name. So we need to change the code slightly but it took a while to figure that out (e.g., I had to look at the source).
> >>> thanks,
> >>> Satish
