[petsc-dev] PetscIntialize docs
Mark F. Adams mfadams at lbl.gov
Thu Sep 5 09:44:40 CDT 2013
>  1) ~username/.petscrc
>  2) cwd/.petscrc
>  3) "code specific file", whose name is passed into PetscIntitialize()
> If you pass in NULL to PetscInitialize(), it will not check option 3). If you pass in a real name to PetscIntiialize(), and
> in the "code specific file" you put -skpi_petscrc, then it will not check options 1) and 2).
You can't put -skip_petscrc in the code specific file.  The whole idea of -skip_petscrc is that it keeps the code from trying to open a file.  The code opens the code specific file first, then command line args, then checks for -skip_petscrc.  So you need to give NULL for the the "file" here and put -skip_petscrc on the command line, if I am reading the code correctly.
>     Matt
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
