[petsc-dev] SNES with linear operator
    Barry Smith
    bsmith at mcs.anl.gov
    Sun Sep  1 18:08:18 CDT 2013
  You mean -snes_type ksponly ?
  Anyways the manual page says:
     SNESKSPONLY - Nonlinear solver that only performs one Newton step and does not compute any norms.
      The main purpose of this solver is to solve linear problems using the SNES interface, without
      any additional overhead in the form of vector operations.
   So I interprete it to mean that for each nonlinear solve it will evaluate the Jacobian (otherwise it is not doing one Newton step) and from the code
 ierr = SNESComputeJacobian(snes,X,&snes->jacobian,&snes->jacobian_pre,&flg);CHKERRQ(ierr);
  ierr = KSPSetOperators(snes->ksp,snes->jacobian,snes->jacobian_pre,flg);CHKERRQ(ierr);
   so clearly it wants to reevaluate the Jacobian for each solve.
Perhaps you also want  SNESSetLagPreconditioner
-  lag - -1 indicates NEVER rebuild, 1 means rebuild every time the Jacobian is computed within a single nonlinear solve, 2 means every second time
         the Jacobian is built etc. -2 indicates rebuild preconditioner at next chance but then never rebuild after that
With this option it will (if coded correctly) reuse the same Jacobian and preconditioner for every SNESSolve() you call (it will just get Jacobian once the first time). I think this is what you want.
   Barry
On Sep 1, 2013, at 5:54 PM, "Mark F. Adams" <mfadams at lbl.gov> wrote:
> I have a SNES solver that runs with a linear operator at times.  I use -ksp_ksponly.  The KSPSetOperator seems to get called every solve because the PC setup code gets called every solve.  Should this be happening?
> Mark
