[petsc-dev] METIS update -> MUMPS crash
Garth N. Wells
gnw20 at cam.ac.uk
Sun Sep 1 13:44:59 CDT 2013
On 1 September 2013 19:27, Matthew Knepley <knepley at gmail.com> wrote:
> On Sun, Sep 1, 2013 at 1:07 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> I see the errors with valgrind - and I don't know the reason. Perhaps
>> we should revert the metis/parmetis upgrade.. [unless someone can debug
>> this..]
>> valgrind doesn't give errors with the older metis-5.0.2
> This looks like a MUMPS bug. I guess we should report to them that they are
> not
> actually compatible with the latest METIS release.
MUMPS releases take place on glacial time scales. METIS is not a
required dependency for MUMPS, so to move the METIS version forward in
PETSc and not break MUMPS you could just configure MUMPS with only
SCOTCH, instead of with METIS and SCOTCH as is presently the case.
Garth
> Matt
>> Satish
>> On Sun, 1 Sep 2013, Garth N. Wells wrote:
>> > I've been having trouble with MUMPS crashing since METIS was recently
>> > updated in
>> > https://bitbucket.org/petsc/petsc/commits/67125ba
>> > The problem does not appear for very small problems, but for other
>> > problems it does. I can reproduce a crash with ex55
>> > (src/ksp/ksp/examples/tutorials/ex55.c):
>> > ./ex55 -ksp_type preonly -pc_type lu -pc_factor_mat_solver_package
>> > mumps -ksp_view -ne 128
>> > For 'ne' less than about 50 it runs fine but crashes for anything
>> > bigger. Changing the LU solver to another package it runs fine.
>> > Backtrace below. The message
>> > http://www.mail-archive.com/petsc-users@mcs.anl.gov/msg17695.html
>> > looks to be related.
>> > Garth
>> > ======= Backtrace: =========
>> > /lib/x86_64-linux-gnu/libc.so.6(+0x80a46)[0x7f877c6f4a46]
>> > /home/garth/local/src/petsc-test/arch-linux2-c-debug/lib/libmetis.so(gk_gkmcorePop+0x81)[0x7f877be7fcae]
>> > /home/garth/local/src/petsc-test/arch-linux2-c-debug/lib/libmetis.so(gk_malloc_cleanup+0x3f)[0x7f877be6c418]
>> > /home/garth/local/src/petsc-test/arch-linux2-c-debug/lib/libmetis.so(METIS_NodeND+0x6de)[0x7f877be9fa02]
>> > /home/garth/local/src/petsc-test/arch-linux2-c-debug/lib/libmetis.so(metis_nodend_+0x48)[0x7f877be94ba8]
>> > /home/garth/local/gcc/petsc-test/lib/libpetsc.so(dmumps_195_+0x3720)[0x7f877e67ac40]
>> > /home/garth/local/gcc/petsc-test/lib/libpetsc.so(dmumps_26_+0x279c)[0x7f877e553d30]
>> > /home/garth/local/gcc/petsc-test/lib/libpetsc.so(dmumps_+0x2022)[0x7f877e638756]
>> > /home/garth/local/gcc/petsc-test/lib/libpetsc.so(dmumps_f77_+0x16eb)[0x7f877e51a567]
>> > /home/garth/local/gcc/petsc-test/lib/libpetsc.so(dmumps_c+0x12a5)[0x7f877e4f2fed]
>> > /home/garth/local/gcc/petsc-test/lib/libpetsc.so(MatLUFactorSymbolic_AIJMUMPS+0xa88)[0x7f877dc00d11]
>> > /home/garth/local/gcc/petsc-test/lib/libpetsc.so(MatLUFactorSymbolic+0xb61)[0x7f877db6a82f]
>> > /home/garth/local/gcc/petsc-test/lib/libpetsc.soAborted (core dumped)
> What most experimenters take for granted before they begin their experiments
> is infinitely more interesting than any results to which their experiments
> lead.
> -- Norbert Wiener
