[petsc-dev] git : list branches started off maint - but not yet merged back
Satish Balay
balay at mcs.anl.gov
Sun Sep 1 10:35:41 CDT 2013
On Sat, 31 Aug 2013, Jed Brown wrote:
> Satish Balay <balay at mcs.anl.gov> writes:
> >> Candidate for maint: refs/remotes/origin/jed/avoid-getpwuid Fri Aug 30 18:10:37 2013 -0700
> >> 6c8deb0 Sys: fix PetscGetFullPath expansion of ~ and ~user, ensure NULL termination
> >> 45082d6 Sys: avoid getpwuid in file path routines
> >> 311ae19 Sys: add failing test expanding ~/file-name and ~user/file-name
> > BTW: perhaps this is a master only change? [because now ~/.petscrc won't work for some folks?]
> I started it from 'maint' because I wanted to have the option. Do we
> know of systems for which getpwuid returns good information about the
> home directory, but for which HOME is not set? Maybe we'll find out if
> people are trying 'next' on funny machines. It would be nice for 3.4.3
> to not have this possible problem on BG.
I suspect it will be tested a bit in master - but wierd machine usage
might primarily be from maint. [i.e release]
> Note that PetscGetFullPath was obviously broken before:
> commit 311ae19d0f5ae5259a6236e6f4ce4509eaf01c8f
> Author: Jed Brown <jedbrown at mcs.anl.gov>
> Date: Fri Aug 30 15:24:26 2013 -0700
> > $(realpath ~/file-name) != /home/jed/petsc/src/sys/examples/tests/~/file-name
> > $(realpath ~jed/file-name) != /home/jed/petsc/src/sys/examples/tests/~jed/file-name
> Satish, do you think we could create a dashboard similar to Karl's
> nightly summary that lists all these merge candidates? Would that be
> too dangerous because it's hard to allow comments on whether a candidate
> is viable?
I can addin a weekly cronjob that sends an e-mail to petsc-dev - this
would allow comments..
[we would have to update the script to remove the branches that
started on or before v3.4 from the listing - or delete these branches
- provided they are done/merged to master.]
Satish
