[petsc-dev] defaulting gnu compilers on Apple
    Barry Smith
    bsmith at mcs.anl.gov
    Thu Oct 31 07:10:17 CDT 2013
   They are not aliases but I cannot determine if there is a difference in functionality
~/Src/petsc  next $ gcc --version
Configured with: --prefix=/Applications/Xcode.app/Contents/Developer/usr --with-gxx-include-dir=/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.9.sdk/usr/include/c++/4.2.1
Apple LLVM version 5.0 (clang-500.2.79) (based on LLVM 3.3svn)
Target: x86_64-apple-darwin13.0.0
Thread model: posix
~/Src/petsc  next $ clang --version
Thread model: posix
~/Src/petsc  next $ ls -l /usr/bin/gcc
-rwxr-xr-x  1 root  wheel  14224 Oct 22 20:01 /usr/bin/gcc
~/Src/petsc  next $ ls -l /usr/bin/clang
-rwxr-xr-x  1 root  wheel  14224 Oct 22 20:01 /usr/bin/clang
~/Src/petsc  next $ diff /usr/bin/clang /usr/bin/gcc
Binary files /usr/bin/clang and /usr/bin/gcc differ
~/Src/petsc  next $ g++ --version
Thread model: posix
~/Src/petsc  next $ clang++ --version
Thread model: posix
~/Src/petsc  next $ diff /usr/bin/clang++ /usr/bin/g++
Binary files /usr/bin/clang++ and /usr/bin/g++ differ
man gcc returns the manual page for gcc (with its huge number of crazy gnu specific stuff) while man clang gives back a smaller clang/llvm manual page.
I guess someone needs to bite the bullet and test the gcc options that are not clang options and see if they work with /usr/bin/gcc
If Xcode’s gcc does not support gcc options then we should not default to using it since that is way confusing!
   Barry
On Oct 31, 2013, at 12:12 AM, Sean Farley <sean.michael.farley at gmail.com> wrote:
> balay at mcs.anl.gov writes:
>>>> unless everyone is using xcode5 - I think gcc/g++ is a safer default.
>>> Apple stopped shipping gcc with Xcode 4.2 [1]. Since that version,
>>> everyone has been using the llvm backend.
>> The isse is clang frontend with xcode4 is buggy [breaks with petsc build]
>> http://lists.mcs.anl.gov/pipermail/petsc-dev/2013-October/thread.html
> It would appear so.
>>> Only in version >= 5.0 has
>>> llvm-gcc been dropped. And in Mavericks only libc++ (and not libstdc++)
>>> is shipped.
>>> [1] http://en.wikipedia.org/wiki/Xcode#Toolchain_Versions
>> Since /usr/bin/gcc is an alias to clang in Xcode5 - there is no need
>> to change defaults on OSX as Barry is suggesting?
> Probably, but I haven't tested.
