[petsc-dev] MatMatSolve and mumps
    Jed Brown
    jedbrown at mcs.anl.gov
    Wed Oct 30 20:51:03 CDT 2013
Jose David Bermeol <jbermeol at purdue.edu> writes:
> So for which solvers MatMatSolve does not work??
There is a default implementation (MatMatSolve_Basic) that just solves
single vector problems in sequence.  So you can use the interface, but
the execution might vary between solvers.
The MUMPS interface is actually a liability here because they insist on
having the entire vector on rank 0.  This is a terrible interface and
not memory-scalable.  If you naively put many RHS vectors on rank 0, you
would likely run out of memory.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131030/27381edb/attachment.sig>
