[petsc-dev] defaulting gnu compilers on Apple
    Barry Smith
    bsmith at mcs.anl.gov
    Wed Oct 30 16:26:32 CDT 2013
On Oct 30, 2013, at 4:19 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> unless everyone is using xcode5 - I think gcc/g++ is a safer default.
   Then you need a check in the logic because gcc/g++ is not a good default with Xcode >= 5.
   You could try clang first and get that it is Apple LLVM version 5.0 (clang-500.2.79) (based on LLVM 3.3svn)  or better.
   Barry
> Satish
> On Wed, 30 Oct 2013, Barry Smith wrote:
>>   Satish,
>>     I think ./configure still defaults to using gcc/g++ on Apple if just run. Can you please change this in petsc-dev to default to the clang compilers clang and clang++
>>   Thanks
>>   Barry
