[petsc-dev] PCGAMG: set default type (AGG);	PCSetUp_GAMG crashes if not set
    Jed Brown
    jedbrown at mcs.anl.gov
    Wed Oct 30 11:06:19 CDT 2013
Matthew Knepley <knepley at gmail.com> writes:
> You can mask it so that it only increments inside Create().
True, but if you do that, you could also mark all those instances and
remove them automatically.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131030/f183d7d4/attachment.sig>
