[petsc-dev] [petsc-maint] valgrind detected	on	/usr/local/include and enabled but header files from this	dir	are not added to build path
    Jed Brown
    jedbrown at mcs.anl.gov
    Tue Oct 29 14:58:22 CDT 2013
Satish Balay <balay at mcs.anl.gov> writes:
> If you look at the current configure.log - its after fortran compiler
> detection.
> Currently the dependencies [for PETSC_ARCH] are:
>     self.petscdir = framework.require('PETSc.utilities.petscdir', self)
>     self.languages = framework.require('PETSc.utilities.languages', self)
>     self.compilerFlags = framework.require('config.compilerFlags', self)
> so it need to get that far before PETSC_ARCH can be set/used..
Okay, but why does it have to go that far?
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131029/7a03c738/attachment.sig>
