[petsc-dev] [petsc-maint] valgrind detected	on	/usr/local/include and enabled but header files from this	dir	are not added to build path
    Satish Balay
    balay at mcs.anl.gov
    Tue Oct 29 14:16:14 CDT 2013
I mistated one thing.
The git-url usage in pacakge.py spills over to tarball users aswell.
Now to have consistant tarballs wrt git repo - we have to migrate all
tarball urls to tarballs from the git repo hosting site. [and not host
at ftp.mcs.anl.gov]
But this is unreliable [the last I checked with elemental at github -
git failed frequently - but it was giving out taballs more reliably]
satish
On Tue, 29 Oct 2013, Barry Smith wrote:
>    Just because you can do it doesn’t mean you should do it.
>    Barry
> On Oct 29, 2013, at 2:07 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >  It is not worthy any additional logic in the already messing configure process to save a few downloads.
> >   Barry
> > On Oct 29, 2013, at 1:59 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> >> On Tue, 29 Oct 2013, Jed Brown wrote:
> >>> Barry Smith <bsmith at mcs.anl.gov> writes:
> >>>>  Or simpler just have the —with-clean nuke external packages; makes
> >>>>  life easy.  By "store the tarballs in a common place” and SHA1 crap
> >>>>  you are making the system more complicated to understand and
> >>>>  maintain.
> >>> People will complain when they have to download the same tarball many
> >>> times.  But I don't especially care as long as the builds are done
> >>> inside $PETSC_ARCH instead of in a common place.  (This is also useful
> >>> when building multiple configurations of PETSc in parallel.)
> >> There is also the issue with git repos to deal with. [presumably the
> >> above logic would be slightly different than the tarballs]
> >> We [Jed and I ] also discussed having git repos and corresponding
> >> tarballs match - and caching tarballs locally for unreliable external
> >> sites. And then using SHA as a way of versioning to eliminate most
> >> cases where with-clean would be needed.
> >> Just a note: all these issues are primarily with git users - not
> >> petsc-release/tarball users.
> >> Satish
