[petsc-dev] [petsc-maint] valgrind detected on	/usr/local/include and enabled but header files from this dir	are not added to build path
    Jed Brown
    jedbrown at mcs.anl.gov
    Tue Oct 29 11:27:02 CDT 2013
Matthew Knepley <knepley at gmail.com> writes:
> If we are hashing the source, why ever keep it around? Just keep the
> hash.  If the hash does not match the tarball we get (either from
> options or by default lookup), unpack it, build it, and store that
> hash, then delete the source.
It's useful to have the source when debugging.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131029/6653bbcf/attachment.sig>
