[petsc-dev] python2 vs python3 wrt configure
    Jed Brown
    jedbrown at mcs.anl.gov
    Thu Oct 24 15:23:10 CDT 2013
Satish Balay <balay at mcs.anl.gov> writes:
>> > But then - as you said - python 2.4 doesn't provide python2
>> Python 2.6.8 (April 2012) does not provide python2!
> so changing 'python' to 'python2' in configure won't help
The front-end "configure" stub, runs in any version of Python, and can
provide a helpful error message.  The question is when people will have
to spell out the path to their Python.
Note that Ubuntu 14.04 (this coming spring) intends to only have python3
in the officially supported repositories (and on installation media).
If you need python2, you'll have to get it from the community
repositories.
https://wiki.ubuntu.com/Python/
With respect to the old versions of Python in the logs, a better
question is which of those machines do not have a more recent version of
Python, perhaps one that you have to invoke using "python2.6" instead of
"python".  The barrier for upgrading is much lower if people can
trivially run configure with a suitably recent Python.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131024/bcb3f716/attachment.sig>
