[petsc-dev] how to rebase together last two commits in branch?
Aron Ahmadia aron at ahmadia.net
Tue Oct 22 14:22:26 CDT 2013
Well, Jed is right :)
On Tue, Oct 22, 2013 at 3:14 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Oct 22, 2013 at 2:03 PM, Aron Ahmadia <aron at ahmadia.net> wrote:
>> As long as you know what you're doing :)
>> git push -f
> Jed was advocating
>   git push origin +barry/myshit
>     Matt
>> On Tue, Oct 22, 2013 at 3:01 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>    Thanks
>>>   Ok, that works but now when I try to push it won't allow. is there
>>> some way to force the push (no one is using this branch it is in a pull
>>> request and needed cleaning)
>>> ~/Src/petsc  barry/reduce-dmsetup-da-memoryusage $ git push
>>> To git at bitbucket.org:petsc/petsc.git
>>>  ! [rejected]        barry/reduce-dmsetup-da-memoryusage ->
>>> barry/reduce-dmsetup-da-memoryusage (non-fast-forward)
>>> error: failed to push some refs to 'git at bitbucket.org:petsc/petsc.git'
>>> hint: Updates were rejected because the tip of your current branch is
>>> behind
>>> hint: its remote counterpart. Merge the remote changes (e.g. 'git pull')
>>> hint: before pushing again.
>>> hint: See the 'Note about fast-forwards' in 'git push --help' for
>>> details.
>>> On Oct 22, 2013, at 1:55 PM, Aron Ahmadia <aron at ahmadia.net> wrote:
>>> > git rebase -i HEAD~2/3
>>> > On Tue, Oct 22, 2013 at 2:53 PM, Barry Smith <bsmith at mcs.anl.gov>
>>> wrote:
>>> >   I would like to put together the last two commits in a branch, how
>>> do I do this?
>>> >  git rebase -i
>>> > doesn't help because it only handles the last commit. How do I tell
>>> git to go back one commit in the rebase?
>>> >    Thanks
>>> >    Barry
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131022/10a80b33/attachment.html>
