[petsc-dev] how to rebase together last two commits in branch?
    Satish Balay
    balay at mcs.anl.gov
    Tue Oct 22 14:06:04 CDT 2013
with a caveat
http://lists.mcs.anl.gov/pipermail/petsc-dev/2013-October/013484.html
satish
On Tue, 22 Oct 2013, Aron Ahmadia wrote:
> As long as you know what you're doing :)
> git push -f
> On Tue, Oct 22, 2013 at 3:01 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >    Thanks
> >   Ok, that works but now when I try to push it won't allow. is there some
> > way to force the push (no one is using this branch it is in a pull request
> > and needed cleaning)
> > ~/Src/petsc  barry/reduce-dmsetup-da-memoryusage $ git push
> > To git at bitbucket.org:petsc/petsc.git
> >  ! [rejected]        barry/reduce-dmsetup-da-memoryusage ->
> > barry/reduce-dmsetup-da-memoryusage (non-fast-forward)
> > error: failed to push some refs to 'git at bitbucket.org:petsc/petsc.git'
> > hint: Updates were rejected because the tip of your current branch is
> > behind
> > hint: its remote counterpart. Merge the remote changes (e.g. 'git pull')
> > hint: before pushing again.
> > hint: See the 'Note about fast-forwards' in 'git push --help' for details.
> > On Oct 22, 2013, at 1:55 PM, Aron Ahmadia <aron at ahmadia.net> wrote:
> > > git rebase -i HEAD~2/3
> > > On Tue, Oct 22, 2013 at 2:53 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > >   I would like to put together the last two commits in a branch, how do
> > I do this?
> > >  git rebase -i
> > > doesn't help because it only handles the last commit. How do I tell git
> > to go back one commit in the rebase?
> > >    Thanks
> > >    Barry
