[petsc-dev] Experimental GNU make build system
    Satish Balay
    balay at mcs.anl.gov
    Fri Oct 18 13:17:13 CDT 2013
I'm rebasing balay/remove-sdir [over master] and merging to next now.
Satish
On Wed, 29 May 2013, Satish Balay wrote:
> ok - pushed this commit - and the removal of __SDIR__ to
> 'balay/remove-sdir' [which is branched off 'jed/gnumake']
> The SDIR removal affects quiet a few routines - and a few
> structures. And its probable I missed fixed something [or fixed
> something incorrectly that the compiler didn't catch]
> Basic builds run fine.
> commit 4a020275677b3c7c915947a9a8df98db6a86b95d
> Author: Satish Balay <balay at mcs.anl.gov>
> Date:   Wed May 29 00:11:17 2013 -0500
>     __SDIR__: remove usage of __SDIR__ from PETSc sources.
> commit ef9cb020c7e6703c909e2bfcf036c7598315ce88
> Date:   Wed May 29 00:09:35 2013 -0500
>     __SDIR__: fix all-legacy targets to use ${PWD} instead of LOCDIR/__INSDIR in compiles
> Satish
> On Tue, 28 May 2013, Satish Balay wrote:
> > On Thu, 23 May 2013, Jed Brown wrote:
> > > Satish Balay <balay at mcs.anl.gov> writes:
> > > > __SDIR__ is primarily needed by 'all-legacy'. cmake/gmake builds are
> > > > using the full paths at compile time - so they don't need it [and are
> > > > using empty LOCDIR]
> > > This should take care of all-legacy:
> > > diff --git i/conf/rules w/conf/rules
> > > index 0fc01dc..f8b70ad 100644
> > > --- i/conf/rules
> > > +++ w/conf/rules
> > > @@ -391,7 +391,7 @@ getautoconfargs:
> > >          if [ $${mypwd} != $${newpwd} ]; then \
> > >           ${OMAKE}  PETSC_ARCH=${PETSC_ARCH}  chk_petscdir;\
> > >          fi
> > > -       ${PETSC_COMPILE_SINGLE} $<
> > > +       ${PETSC_COMPILE_SINGLE} ${PWD}/$<
> > >         @if [ "${PETSCPORTABLE}" != "" ]; then \
> > >            ${PYTHON} ${PETSC_DIR}/bin/portabilitycheck.py $*.o ; \
> > >          fi
> > I guess fortran sources don't need __SDIR__ - so the corresponding
> > targets don't need changes.
> > And we can use the following to get libfast working [This works with
> > solaris-make & bsd-make aswell]
> > PSOURCEC  = $(SOURCEC:%=${PWD}/%)
> > I did a basic buid withe the following [checked on
> > linux,solaris,windows] - and it appears to work fine [assuming
> > "unknowndirectory/" stuff will be removed with other __SDIR__ changes]
> > 2 Differences are [these should be ok]:
> > - full path listed in error messages.
> > '/export/home/petsc/petsc.clone/src/ksp/pc/interface/pcset.c'
> > [ vs previous message with 'src/ksp/pc/interface/pcset.c']
> > - The compilers now spit out the full file names. [as thats what we pass to them]
> > libfast in: /export/home/petsc/petsc.clone/src/sys/classes/viewer/interface
> > /export/home/petsc/petsc.clone/src/sys/classes/viewer/interface/view.c:
> > /export/home/petsc/petsc.clone/src/sys/classes/viewer/interface/flush.c:
> > /export/home/petsc/petsc.clone/src/sys/classes/viewer/interface/viewregall.c:
> > /export/home/petsc/petsc.clone/src/sys/classes/viewer/interface/viewreg.c:
> > /export/home/petsc/petsc.clone/src/sys/classes/viewer/interface/viewa.c:
> > /export/home/petsc/petsc.clone/src/sys/classes/viewer/interface/dlregispetsc.c:
> > /export/home/petsc/petsc.clone/src/sys/classes/viewer/interface/viewers.c:
> > /export/home/petsc/petsc.clone/src/sys/classes/viewer/interface/dupl.c:
> > libfast in: /export/home/petsc/petsc.clone/src/sys/classes/viewer/interface/ftn-auto
> > Satish
> > petsc at n-gage:~/petsc.clone/src/ksp/ksp/examples/tutorials$ ./ex2 -pc_type foobar
> > [0]PETSC ERROR: --------------------- Error Message ------------------------------------
> > [0]PETSC ERROR: Unknown type. Check for miss-spelling or missing external package needed for type:
> > see http://www.mcs.anl.gov/petsc/documentation/installation.html#external!
> > [0]PETSC ERROR: Unable to find requested PC type foobar!
> > [0]PETSC ERROR: ------------------------------------------------------------------------
> > [0]PETSC ERROR: Petsc Release Version 3.4.0, unknown
> > [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> > [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> > [0]PETSC ERROR: See docs/index.html for manual pages.
> > [0]PETSC ERROR: ./ex2 on a arch-opensolaris-pkgs-opt named n-gage by petsc Tue May 28 20:37:00 2013
> > [0]PETSC ERROR: Libraries linked from /export/home/petsc/petsc.clone/arch-opensolaris-pkgs-opt/lib
> > [0]PETSC ERROR: Configure run at Tue May 28 13:25:16 2013
> > [0]PETSC ERROR: Configure options --with-debugger=/bin/true --with-debugging=0 --download-mpich=1 --with-c2html=0 --download-cmake=1 --download-metis=1 --download-parmetis=1 --download-triangle=1 --download-superlu=1 --download-superlu_dist=1 --download-f-blas-lapack=1 --download-scalapack=1 --download-mumps=1 --download-sundials=1 --download-hypre=1 --download-umfpack=1 --download-chaco=1 --download-spai=1 --with-no-output -PETSC_ARCH=arch-opensolaris-pkgs-opt -PETSC_DIR=/export/home/petsc/petsc.clone
> > [0]PETSC ERROR: PCSetType() line 68 in "unknowndirectory/"/export/home/petsc/petsc.clone/src/ksp/pc/interface/pcset.c
> > [0]PETSC ERROR: PCSetFromOptions() line 163 in "unknowndirectory/"/export/home/petsc/petsc.clone/src/ksp/pc/interface/pcset.c
> > [0]PETSC ERROR: KSPSetFromOptions() line 357 in "unknowndirectory/"/export/home/petsc/petsc.clone/src/ksp/ksp/interface/itcl.c
> > [0]PETSC ERROR: main() line 192 in "unknowndirectory/"/export/home/petsc/petsc.clone/src/ksp/ksp/examples/tutorials/ex2.c
> > application called MPI_Abort(MPI_COMM_WORLD, 86) - process 0
> > [unset]: aborting job:
> > diff --git a/conf/rules b/conf/rules
> > index 0fc01dc..64ff8d8 100644
> > --- a/conf/rules
> > +++ b/conf/rules
> >          fi
> >          fi
> > @@ -399,16 +399,16 @@ getautoconfargs:
> >  #   Compiles CUDA code
> >  .cu.o:
> > -	${PETSC_CUCOMPILE_SINGLE} $<
> > +	${PETSC_CUCOMPILE_SINGLE} ${PWD}/$<
> >  .cu.a:
> >  	-${AR} ${AR_FLAGS} ${LIBNAME} $*.o
> >  	-if test -n "${LIBTOOL}"; then ${AR} ${AR_FLAGS} ${LT_LIBNAME} $*.lo; fi
> >  	-${RM} $*.o $*.lo
> >  .c.a .cpp.a .cc.a .C.a:
> > -	-${PETSC_COMPILE_SINGLE} $<
> > +	-${PETSC_COMPILE_SINGLE} ${PWD}/$<
> >  	-${RM} $*.o $*.lo
> > diff --git a/conf/variables b/conf/variables
> > index 79ce8ba..bd65385 100644
> > --- a/conf/variables
> > +++ b/conf/variables
> > @@ -10,7 +10,7 @@
> >  PETSC_LIB_DIR	     = ${PETSC_DIR}/${PETSC_ARCH}/lib
> > -PETSC_CCPPFLAGS	    = ${PETSC_CC_INCLUDES} ${PETSCFLAGS} ${CPP_FLAGS} ${CPPFLAGS} -D__INSDIR__=${LOCDIR}
> > +PETSC_CCPPFLAGS	    = ${PETSC_CC_INCLUDES} ${PETSCFLAGS} ${CPP_FLAGS} ${CPPFLAGS}
> >  PETSC_FCPPFLAGS	    = ${PETSC_FC_INCLUDES} ${PETSCFLAGS} ${FPP_FLAGS} ${FPPFLAGS}
> >  PETSC_C_SH_LIB_PATH = ${CC_LINKER_SLFLAG}${PETSC_LIB_DIR}
> >  PETSC_F_SH_LIB_PATH = ${FC_LINKER_SLFLAG}${PETSC_LIB_DIR}
> > @@ -30,10 +30,12 @@ F_SH_LIB_PATH	= ${PETSC_F_SH_LIB_PATH}
> >  # The following variables define PETSc compile procedures
> > -PETSC_COMPILE         = ${PCC} -c ${PCC_FLAGS} ${CFLAGS} ${CCPPFLAGS}  ${SOURCEC}
> > +PSOURCEC  = $(SOURCEC:%=${PWD}/%)
> > +PSOURCECU = $(SOURCECU:%=${PWD}/%)
> > +PETSC_COMPILE         = ${PCC} -c ${PCC_FLAGS} ${CFLAGS} ${CCPPFLAGS}  ${PSOURCEC}
> >  PETSC_COMPILE_SINGLE  = ${PCC} -o $*.o -c ${PCC_FLAGS} ${CFLAGS} ${CCPPFLAGS}
> >  PETSC_FCOMPILE        = ${FC} -c ${FC_FLAGS} ${FFLAGS} ${FCPPFLAGS}  ${SOURCEF}
> > -PETSC_CUCOMPILE       = ${CUDAC} ${CUDAC_FLAGS} -c --compiler-options="${PCC_FLAGS} ${CFLAGS} ${CCPPFLAGS}" ${SOURCECU}
> > +PETSC_CUCOMPILE       = ${CUDAC} ${CUDAC_FLAGS} -c --compiler-options="${PCC_FLAGS} ${CFLAGS} ${CCPPFLAGS}" ${PSOURCECU}
> >  PETSC_CUCOMPILE_SINGLE= ${CUDAC} -o $*.o ${CUDAC_FLAGS} -c --compiler-options="${PCC_FLAGS} ${CFLAGS} ${CCPPFLAGS}"
> >  # define OBJSC and OBJSF OBJSCU
