[petsc-dev] nightly build errros with next
    Satish Balay
    balay at mcs.anl.gov
    Thu Oct 17 10:18:21 CDT 2013
Should have included this..
         CXX arch-linux-complex-gcov/obj/src/snes/interface/snesut.o
src/snes/interface/snesut.c: In function ‘PetscErrorCode SNESSetWorkVecs(SNES, PetscInt)’:
src/snes/interface/snesut.c:560:34: error: ‘DMGetGlobalVector’ was not declared in this scope
   ierr = DMGetGlobalVector(dm, &v);CHKERRQ(ierr);
src/snes/interface/snesut.c:562:38: error: ‘DMRestoreGlobalVector’ was not declared in this scope
   ierr = DMRestoreGlobalVector(dm, &v);CHKERRQ(ierr);
make[2]: *** [arch-linux-complex-gcov/obj/src/snes/interface/snesut.o] Error 1
make[2]: Leaving directory `/sandbox/balay/petsc.clone'
satish
On Thu, 17 Oct 2013, Satish Balay wrote:
> Matt,
> I see these errors in yesterday's 'master' build. Perhaps the fixes
> need to be merged to master aswell?
> Satish
> On Tue, 15 Oct 2013, Matthew Knepley wrote:
> > On Tue, Oct 15, 2013 at 11:30 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > Fixed.
> >    Matt
> > From build_next_arch-freebsd-cxx-cmplx-pkgs-dbg_wii.log
> > > [ 72%] Building CXX object
> > > CMakeFiles/petsc.dir/src/dm/impls/composite/f90-custom/zfddaf90.c.o
> > > /usr/home/balay/petsc.clone-3/src/dm/dt/interface/dtfe.c: In function
> > > 'PetscErrorCode PetscFEGetTabulation(_p_PetscFE*, PetscInt, const
> > > PetscReal*, PetscReal**, PetscReal**, PetscReal**)':
> > > /usr/home/balay/petsc.clone-3/src/dm/dt/interface/dtfe.c:2264: warning:
> > > unused variable 'n'
> > > unused variable 'info'
> > > [ 93%] Building CXX object
> > > CMakeFiles/petsc.dir/src/snes/interface/snesut.c.o
> > > /usr/home/balay/petsc.clone-3/src/snes/interface/snesut.c: In function
> > > 'PetscErrorCode SNESSetWorkVecs(_p_SNES*, PetscInt)':
> > > /usr/home/balay/petsc.clone-3/src/snes/interface/snesut.c:560: error:
> > > 'DMGetGlobalVector' was not declared in this scope
> > > /usr/home/balay/petsc.clone-3/src/snes/interface/snesut.c:562: error:
> > > 'DMRestoreGlobalVector' was not declared in this scope
> > > *** [CMakeFiles/petsc.dir/src/snes/interface/snesut.c.o] Error code 1
> > > 1 error
> > > From build_next_arch-freebsd-cxx-pkgs-opt_wii.log
> > > [ 48%] Building CXX object
> > > CMakeFiles/petsc.dir/src/mat/impls/aij/seq/mattransposematmult.c.o
> > > /usr/home/balay/petsc.clone-2/src/mat/impls/aij/seq/inode.c: In function
> > > 'PetscErrorCode MatSOR_SeqAIJ_Inode(_p_Mat*, _p_Vec*, PetscReal,
> > > MatSORType, PetscReal, PetscInt, PetscInt, _p_Vec*)':
> > > /usr/home/balay/petsc.clone-2/src/mat/impls/aij/seq/inode.c:2761: warning:
> > > 'v5' may be used uninitialized in this function
> > > 'v4' may be used uninitialized in this function
> > > [ 49%] Building CXX object
> > > CMakeFiles/petsc.dir/src/mat/impls/aij/seq/bas/basfactor.c.o
> > > 'v3' may be used uninitialized in this function
> > > 'v2' may be used uninitialized in this function
> > > /usr/home/balay/petsc.clone-2/src/mat/impls/aij/seq/inode.c:2758: warning:
> > > 'sum5' may be used uninitialized in this function
> > > 'sum4' may be used uninitialized in this function
> > > 'sum3' may be used uninitialized in this function
> > > 'sum2' may be used uninitialized in this function
> > > 'v1' may be used uninitialized in this function
> > > 'sum1' may be used uninitialized in this function
> > > [ 69%] Building CXX object
> > > CMakeFiles/petsc.dir/src/dm/impls/plex/plexreorder.c.o
> > > /usr/home/balay/petsc.clone-2/src/dm/impls/plex/plexreorder.c: In function
> > > 'PetscErrorCode DMPlexPermute(_p_DM*, _p_IS*, _p_DM**)':
> > > /usr/home/balay/petsc.clone-2/src/dm/impls/plex/plexreorder.c:179:
> > > warning: 'labelNew' may be used uninitialized in this function
> > > [ 71%] Building CXX object
> > > /usr/home/balay/petsc.clone-2/src/dm/dt/interface/dtfe.c: In function
> > > 'PetscErrorCode PetscFEIntegrateBdResidual_Basic(_p_PetscFE*, PetscInt,
> > > PetscInt, _p_PetscFE**, PetscInt, PetscCellGeometry, const PetscScalar*,
> > > PetscInt, _p_PetscFE**, const PetscScalar*, void (*)(const PetscScalar*,
> > > const PetscScalar*, const PetscScalar*, const PetscScalar*, const
> > > PetscReal*, const PetscReal*, PetscScalar*), void (*)(const PetscScalar*,
> > > PetscReal*, const PetscReal*, PetscScalar*), PetscScalar*)':
> > > /usr/home/balay/petsc.clone-2/src/dm/dt/interface/dtfe.c:2552: warning:
> > > 'gradA' may be used uninitialized in this function
> > > 'PetscErrorCode PetscFEIntegrateResidual_Basic(_p_PetscFE*, PetscInt,
> > > PetscReal*, PetscScalar*), void (*)(const PetscScalar*, const PetscScalar*,
> > > const PetscScalar*, const PetscScalar*, const PetscReal*, PetscScalar*),
> > > PetscScalar*)':
> > > /usr/home/balay/petsc.clone-2/src/dm/dt/interface/dtfe.c:2353: warning:
> > > CMakeFiles/petsc.dir/src/dm/impls/da/f90-custom/zdaindexf90.c.o
> > > 'PetscErrorCode PetscFEIntegrateJacobian_Basic(_p_PetscFE*, PetscInt,
> > > PetscInt, _p_PetscFE**, PetscInt, PetscInt, PetscCellGeometry, const
> > > PetscScalar*, PetscInt, _p_PetscFE**, const PetscScalar*, void (*)(const
> > > PetscScalar*, const PetscScalar*, const PetscScalar*, const PetscScalar*,
> > > const PetscReal*, PetscScalar*), void (*)(const PetscScalar*, const
> > > PetscScalar*, const PetscScalar*, const PetscScalar*, const PetscReal*,
> > > PetscScalar*), void (*)(const PetscScalar*, const PetscScalar*, const
> > > PetscScalar*, const PetscScalar*, const PetscReal*, PetscScalar*), void
> > > (*)(const PetscScalar*, const PetscScalar*, const PetscScalar*, const
> > > PetscScalar*, const PetscReal*, PetscScalar*), PetscScalar*)':
> > > /usr/home/balay/petsc.clone-2/src/dm/dt/interface/dtfe.c:2762: warning:
> > > Satish
