[petsc-dev] PETSc-3.4 PR open at https://github.com/Homebrew/homebrew-science/pull/343
Aron Ahmadia
aron at ahmadia.net
Sat Oct 12 17:13:52 CDT 2013
> Debugging symbols are much more about disk space than performance.
Agreed. And the current conventions still only support one version of
a library. I think the automated installer giving you a well-tuned
and performant library should still be the default. Anybody who wants
to build a debugging build with the intense PETSc debugging support
can use the PETSC_DIR/PETSC_ARCH technique.
A
