[petsc-dev] elemental in nightly builds with g++-4.6
    Satish Balay
    balay at mcs.anl.gov
    Wed Oct  9 17:54:48 CDT 2013
one more issue. I can't use --download-hdf5 with --download-elemental [in the same build]
For now -I'll disable elemental in current nightly builds - and figureout how to add it later.
[perhaps with elemental only with gcc-8 or llvm on a separate build]
Satish
TEST checkInclude from config.headers(/sandbox/balay/petsc.test/config/BuildSystem/config/headers.py:86)
TESTING: checkInclude from config.headers(config/BuildSystem/config/headers.py:86)
  Checks if a particular include file can be found along particular include paths
Checking for header files ['hdf5.h'] in ['/sandbox/balay/petsc.test/arch-linux-pkgs-cxx-mlib/include']
              Checking include with compiler flags var CPPFLAGS ['/sandbox/balay/petsc.test/arch-linux-pkgs-cxx-mlib/include', '/sandbox/balay/petsc.test/arch-linux-pkgs-cxx-mlib/include', '/sandbox/balay/petsc.test/arch-linux-pkgs-cxx-mlib/include']
Executing: /sandbox/balay/petsc.test/arch-linux-pkgs-cxx-mlib/bin/mpicxx -E  -I/tmp/petsc-IesedN/config.setCompilers -I/tmp/petsc-IesedN/config.headers    -I/sandbox/balay/petsc.test/arch-linux-pkgs-cxx-mlib/include -I/sandbox/balay/petsc.test/arch-linux-pkgs-cxx-mlib/include -I/sandbox/balay/petsc.test/arch-linux-pkgs-cxx-mlib/include /tmp/petsc-IesedN/config.headers/conftest.cc
<snip>
stderr:
In file included from /sandbox/balay/petsc.test/arch-linux-pkgs-cxx-mlib/include/hdf5.h:24:0,
                 from /tmp/petsc-IesedN/config.headers/conftest.cc:3:
/sandbox/balay/petsc.test/arch-linux-pkgs-cxx-mlib/include/H5public.h:198:33: warning: invalid suffix on literal; C++11 requires a space between literal and identifier [-Wliteral-suffix]
 #   define H5_PRINTF_HADDR_FMT  "%"H5_PRINTF_LL_WIDTH"u"
Source:
#include "confdefs.h"
#include "conffix.h"
#include <hdf5.h>
            Popping language Cxx
<snip>
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
Downloaded hdf5 could not be used. Please check install in /sandbox/balay/petsc.test/arch-linux-pkgs-cxx-mlib
  File "/sandbox/balay/petsc.test/config/configure.py", line 293, in petsc_configure
    framework.configure(out = sys.stdout)
  File "/sandbox/balay/petsc.test/config/BuildSystem/config/framework.py", line 933, in configure
    child.configure()
  File "/sandbox/balay/petsc.test/config/BuildSystem/config/package.py", line 572, in configure
    self.executeTest(self.configureLibrary)
  File "/sandbox/balay/petsc.test/config/BuildSystem/config/base.py", line 126, in executeTest
    ret = test(*args,**kargs)
  File "/sandbox/balay/petsc.test/config/BuildSystem/config/packages/hdf5.py", line 82, in configureLibrary
    config.package.Package.configureLibrary(self)
  File "/sandbox/balay/petsc.test/config/BuildSystem/config/package.py", line 500, in configureLibrary
    for location, directory, lib, incl in self.generateGuesses():
  File "/sandbox/balay/petsc.test/config/BuildSystem/config/package.py", line 239, in generateGuesses
    raise RuntimeError('Downloaded '+self.package+' could not be used. Please check install in '+d+'\n')
