[petsc-dev] elemental in nightly builds with g++-4.6
    Satish Balay
    balay at mcs.anl.gov
    Wed Oct  9 15:59:32 CDT 2013
Ah - its the git vs tarball download stuff :(
<<<successful build with old tarball?>>>>>>>
                  ERROR: Could not execute "['git', 'clone', 'https://github.com/elemental/Elemental', '/sandbox/balay/petsc.clone/externalpackages/elemental']":
Cloning into '/sandbox/balay/petsc.clone/externalpackages/elemental'...error: Failed connect to github.com:443; Connection timed out while accessing https://github.com/elemental/Elemental/info/refs
fatal: HTTP request failed
                    Downloading http://libelemental.org/pub/releases/elemental-0.81.tgz to /sandbox/balay/petsc.clone/externalpackages/_d_elemental-0.81.tgz
<<<<<<<<<<<<<<<<<< failed build>>>>>>>>>>>>>>>
Executing: ['git', 'clone', 'https://github.com/elemental/Elemental', '/sandbox/petsc/petsc.clone-3/externalpackages/elemental']
stdout: Cloning into '/sandbox/petsc/petsc.clone-3/externalpackages/elemental'...
Executing: ['git', 'checkout', '-f', '89e7ddc52db68dc5a3f2635733293d7349dbd518']
                  Looking for ELEMENTAL in directory starting with elemental
Satish
On Wed, 9 Oct 2013, Satish Balay wrote:
> ok - I've attempted another build with 4.6 - now this goes through fine.
> Attaching corresponding configure.log.
> Satish
> > Configure goes through fine - but elemental fails.
> > If gcc-4.6 is not suitable - either elemental configure [or petsc configure]
> > should have an appropriate check before attempting this build?
> > http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2013/10/09/build_next_arch-linux-pkgs-cxx-mlib_grind.log
> > http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2013/10/09/configure_next_arch-linux-pkgs-cxx-mlib_grind.log
> > For some reason when I attempted this manually yesterday - it
> > worked. [again worked today with one of my attempts] - but most of my
> > retries today failed. wierd..
> > [it works with +gcc-4.7.3 or +gcc-4.8.0 though]
> > Satish
