[petsc-dev] PETSc on OS X 10.8.x with Apple clang
    Satish Balay
    balay at mcs.anl.gov
    Wed Oct  9 11:37:45 CDT 2013
On Wed, 9 Oct 2013, Jed Brown wrote:
> Satish Balay <balay at mcs.anl.gov> writes:
> > The nightlybuilds on OSX are primarily with gcc. We don't have a build
> > with clang.
> > I have Xcode 4.6 on OSX 10.8. I just attempted a build with clang and see errors.
> Definitely looks like a bug in Clang, but there are newer versions so
> there's probably no point reporting it unless you can reproduce with the
> current version.
Lisandro is using the current version on OSX [same as Barry] - and getting errors.
Lisandro,
Can you send your build logs?
Satish
