[petsc-dev] damn symlinks on windows
    Satish Balay
    balay at mcs.anl.gov
    Wed Oct  9 11:11:51 CDT 2013
On Tue, 8 Oct 2013, Chetan Jhurani wrote:
> mklink on NTFS does it the right way - no .lnk business
> or cygwin specific file format.
> http://en.wikipedia.org/wiki/NTFS_symbolic_link
Hm..
Please note: For Windows 2000/XP, you would use an NTFS junction point.
The mklink command is used to create a symbolic link. It is natively available in the Command Prompt in Windows Vista/2008+ (not in PowerShell or as an executable).
Looks like its not really portable across all versions. And I wonder
if anyone is still using FAT32 for local drives.
C:\Users\balay>mklink
Creates a symbolic link.
MKLINK [[/D] | [/H] | [/J]] Link Target
        /D      Creates a directory symbolic link.  Default is a file
                symbolic link.
        /H      Creates a hard link instead of a symbolic link.
        /J      Creates a Directory Junction.
        Link    specifies the new symbolic link name.
        Target  specifies the path (relative or absolute) that the new link
                refers to.
C:\Users\balay>where mklink
INFO: Could not find files for the given pattern(s).
C:\Users\balay>bash
balay at msnehalem2 /cygdrive/c/Users/balay
$ mklink
bash: mklink: command not found
Hm - Looks like this is this a built in feature for 'cmd' - and not useable from bash.
[Searching c: drive doesn't show anything]
Satish
