[petsc-dev] damn symlinks on windows
Wed Oct 9 07:02:13 CDT 2013
Aron Ahmadia <aron at ahmadia.net> writes:
> I don't understand why you guys create a symbolic link to the
> configure.log in the base directory.  This has always confused me, and
> I'm pretty sure I've accidentally sent a symbolic link or two from OS
> X at one point or another.  I think you should gzip and cp the
> configure.log over as part of a successful install, and leave it
> sitting in the main directory otherwise.
I think configure.log should always be created in
$PETSC_ARCH/conf/configure.log.  It can be symlinked or copied to the
root directory at some later time, but creating it in the root directory
is an unnecessary race between multiple configure processes.
I would like to always gziping the results to keep our mailing list data
volume down.
> Advanced users may want to have the ability to have configure.log
> generated elsewhere (and you could make this a configure argument if
> you really felt like it),
Actually, this would be useful because it would allow building a custom
version of PETSc without having write access to the directory containing
the source code.  So for example, you could create a new PETSC_ARCH from
a system-wide copy of the source code without needing to copy it to your
home directory first.
> but the symbolic links are both unexpected and confusing to beginners.
Well, symbolic links work properly on real operating systems. ;-)
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131009/89224260/attachment.sig>
