[petsc-dev] Supporting --download-hdf5 in Cygwin?
    Richard Tran Mills
    rtm at eecs.utk.edu
    Mon Oct  7 12:19:54 CDT 2013
Thanks, Matt.  It would be good if we could get this into master a little
bit earlier since I'd like to send out instructions to the workshop
participants ahead of time so that they can build PETSc and PFLOTRAN
before they get there. But I guess I could just give instructions to
update the particular commit that has the change if I need to.
Richard
On 10/7/13 1:11 PM, Matthew Knepley wrote:
> On Mon, Oct 7, 2013 at 11:58 AM, Satish Balay <balay at mcs.anl.gov
> <mailto:balay at mcs.anl.gov>> wrote:
>     perhaps isCygwin() should be changed to isWindows()
> This has been merged to next. If it passes a two days of builds, we can
> merge it to master. Is that enough time?
>   Matt
>     satish
>     On Mon, 7 Oct 2013, Matthew Knepley wrote:
>     > On Mon, Oct 7, 2013 at 11:51 AM, Satish Balay <balay at mcs.anl.gov
>     > > Hm self.downloadonWindows is supposed to be for MS compilers only.
>     >       if self.download and
>     > self.framework.argDB.get('download-'+self.downloadname.lower())
>     and not
>     > self.downloadonWindows and self.setCompilers.isCygwin():
>     >         raise RuntimeError('External package '+self.name
>     <http://self.name>+' does not support
>     > --download-'+self.downloadname.lower()+' on Microsoft Windows')
>     >    Matt
>     > > If thats not the case - the bug is somewere else..
>     > > satish
>     > > On Mon, 7 Oct 2013, Richard Tran Mills wrote:
>     > > > Matt,
>     > > > I tried this and it works under 32-bit Cygwin.  It should also
>     work under
>     > > > 64-bit Cygwin except that it hits an error when building the
>     'h5ls'
>     > > target
>     > > > (can overcome this by telling make to ignore errors or by
>     making a small
>     > > patch
>     > > > to the relevant HDF5 code--this is a Cygwin64/HDF5 problem and has
>     > > nothing to
>     > > > do with BuildSystem).
>     > > > Can we go ahead and get this change into 'master' ASAP?  I am
>     not sure
>     > > of the
>     > > > proper workflow to use for such a small change as this.  I'd like
>     > > > --download-hdf5 to be working before I leave for Germany in a
>     few days
>     > > to do a
>     > > > short course there.
>     > > > --Richard
>     > > > On 10/4/13 5:45 PM, Matthew Knepley wrote:
>     > > > > On Fri, Oct 4, 2013 at 4:42 PM, Richard Tran Mills
>     <rtm at eecs.utk.edu <mailto:rtm at eecs.utk.edu>
>     > > > > <mailto:rtm at eecs.utk.edu <mailto:rtm at eecs.utk.edu>>> wrote:
>     > > > >     Hi Satish,
>     > > > >     I got this message attempting to use the Gnu compilers;
>     that's all
>     > > > >     that I've got on this system.  Should I send the
>     configure.log to
>     > > > >     petsc-maint?
>     > > > > Want to add
>     > > > >   self.downloadonWindows   = 1
>     > > > > to __init__ of config/BuildSystem/config/packages/hdf5.py
>     and see if it
>     > > > > work?
>     > > > >   Thanks,
>     > > > >     Matt
>     > > > >     --Richard
>     > > > >     On 10/4/13 4:34 PM, Satish Balay wrote:
>     > > > >         On Fri, 4 Oct 2013, Richard Tran Mills wrote:
>     > > > >             Hi Folks,
>     > > > >             If I tell configure.py '--download-hdf5=1', I
>     get a message
>     > > > >             that "External
>     > > > >             package hdf5 does not support --download-hdf5 on
>     Microsoft
>     > > > >             Windows".  However,
>     > > > >             I just built HDF5 1.8.11 from source under
>     64-bit Cygwin
>     > > > >             and, except for one
>     > > > >             problem with building the 'h5ls' utility, it
>     appears that
>     > > > >             this ought to work.
>     > > > >             Can we support this? And what is the procedure
>     for changing
>     > > > >             package
>     > > > >             configuration info in BuildSystem these days?
>      These files
>     > > > >             show up in the
>     > > > >             'petsc' repo but there appears to be a
>     'buildsystem' repo
>     > > on
>     > > > >             BitBucket as
>     > > > >             well; not sure what the relationship is between
>     them.
>     > > > >         When you say 'Supporting --download-hdf5 in Cygwin'
>     and refer
>     > > to
>     > > > >         64-bit - you
>     > > > >         mean MS compilers or cygwin gcc/gfortran?
>     > > > >         The error message should come up only with MS compilers.
>     > > > >         Presumably --download-hdf5 should work with gnu
>     compilers - if
>     > > > >         it doesn't - it
>     > > > >         probably needs some tweaking.
>     > > > >         Wrt repo - we now have a single git repo
>     > > > > bitbucket.org/petsc/petsc <http://bitbucket.org/petsc/petsc>
>     > > > >         where all petsc/buildsystem changes should go to.
>     > > > >         Satish
>     > > > > What most experimenters take for granted before they begin their
>     > > experiments
>     > > > > is infinitely more interesting than any results to which their
>     > > experiments
>     > > > > lead.
>     > > > > -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
Richard Tran Mills, Ph.D.
Computational Earth Scientist      | Joint Assistant Professor
Hydrogeochemical Dynamics Team     | EECS and Earth & Planetary Sciences
Oak Ridge National Laboratory      | University of Tennessee, Knoxville
E-mail: rmills at ornl.gov  V: 865-241-3198 http://climate.ornl.gov/~rmills
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131007/c11b8e98/attachment.html>
