[petsc-dev] [petsc-users] mkl-cpardiso configuration
    Satish Balay
    balay at mcs.anl.gov
    Sun Oct  6 20:57:50 CDT 2013
If one specifies '--with-mkl=/foo/bar --download-f-blas-lapack' or
just '--with-mlk=/foo/bar' where configure picks up /usr/lib/libblas.a
etc - then things will break.
So somehow these two options should work together - and perhaps the
way they can do is within blaslapack.py [and not a separate mkl.py]
Satish
On Sun, 6 Oct 2013, Jose David Bermeol wrote:
> Exactly
> From: "Barry Smith" <bsmith at mcs.anl.gov>
> To: "Matthew Knepley" <knepley at gmail.com>
> Cc: "Jose David Bermeol" <jbermeol at purdue.edu>, petsc-users at mcs.anl.gov, "For users of the development version of PETSc" <petsc-dev at mcs.anl.gov>
> Sent: Sunday, October 6, 2013 9:49:59 PM
> Subject: Re: [petsc-dev] [petsc-users] mkl-cpardiso configuration
>    Because he is using other stuff in mkl besides blas/lapack!
> On Oct 6, 2013, at 8:43 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > On Sun, Oct 6, 2013 at 8:04 PM, Jose David Bermeol <jbermeol at purdue.edu> wrote:
> > Hi, one question about how to configure a new package, intel people suggest to compile mkl-cpardiso using the following flags for the linker:
> > -Wl,--start-group -L$(MKL_PATH)/lib/intel64/ -lmkl_intel_lp64 -lmkl_intel_thread -lmkl_core -Wl,--end-group -lpthread -lm -liomp5
> > Now I want to be able to do this just using the flag --with-mkl-dir=$(MKL_PATH) during Petsc configuration. I've been trying to modify my mkl.py file to achieve this, however your configuration system is a little bit complex, so if you code give some guidelines to achieve this or files to look how to do it would be great.
>    Make a pull request with all your current stuff and we can look at how you've organized it and make suggestions. Otherwise it is too much email guess work with incomplete information.
>    Barry
> > Is there a reason you do not want to use --with-blas-lapack-lib?
> >   Thanks,
> >     Matt
> > Thanks
> > What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> > -- Norbert Wiener
