[petsc-dev] C++11, compatibility versus simplicity
Tim Tautges tautges at mcs.anl.gov
Fri Oct 4 09:39:43 CDT 2013
On 10/03/2013 05:41 PM, Jed Brown wrote:
> Tim Tautges <tautges at mcs.anl.gov> writes:
>> Sure, but that doesn't mean they will.  To me, ABI incompatibility
>> means I'll be more conservative about going there, not less, no matter
>> how good an idea it would otherwise be technically.
> "Switching your default C++ compilation type in response to one (of very
> many) of your dependent libs changing theirs seems odd ..."
> I thought you were suggesting that when we use Elemental, we should only
> compile those interface files as C++11 and compile all the others with
> the old dialect.  ABI issues make that unworkable.  I'm not planning to
> change the default, but people using Elemental will have to configure
> --with-cxx-dialect=C++11 so that we build everything consistently.
> Those people should be explicitly aware of the ABI problem, though we
> know many of them will try to use some incompatible build of another
> library and we'll end up debugging over email.
Ok, then this discussion is moot (I thought you were going to change the default).  Making it possible with an option,
and adding checks on dependent libs to make sure they're also built with that version of C++, is of course the right
thing to do.
>> One of the annoying things about C++ is that there's always been this
>> piecemeal approach to compatibility, rather than being wholly
>> compliant or not.  I'm not sure whether that's a problem with the
>> standard being too liberal or the/some compiler developers being lazy.
> The standard makes it hard as hell to define a binary interface, so each
> vendor does their own thing and shared libraries can rarely just be
> upgraded.  Fortran has this same problem, but worse.
Yeah.
>> I'm sure Jack is doing great stuff (hi Jack, I'm Tim...), and
>> hopefully he's using something in C++11 that is just so good it's
>> worthwhile requiring his applications to support that dialect.
> Looks like the mailing list had just switched away from google groups
> and wasn't yet being archived, but here's Jack's original message:
That's useful to see, and clearly Jack you didn't make the decision lightly (au contraire, looks like even preserving
compatibility would have involved more effort than normal; decisions like that are always difficult...)
- tim
> On Wed, Aug 7, 2013 at 3:32 PM, Jack Poulson <poulson at stanford.edu> wrote:
>> Dear all,
>> I'm well aware that there will be outcry, but I've backed off of this
>> issue for months now due to some very vocal previous responses. But it's
>> actively preventing the library from growing in several productive ways:
>> 1) C++11 finally guarantees the assumed memory model for std::complex,
>> and, perhaps more importantly, allows for the direct manipulation of the
>> real and imaginary components (I really have no idea why this was not
>> originally supported). With these additions, I feel comfortable getting
>> rid of the current from-scratch elem::Complex implementation, though,
>> pragmatically, it should still be a thin wrapper around std::complex
>> rather than simply a typedef, as:
>>    (a) only float, double, and log double instantiations are considered
>> legal [1,p.890], and so higher-precision support will need to be
>> manually handled, and
>>    (b) we might want to support complex datatypes whose base type is a
>> ring rather than a field, for example, to run a distributed Gemm where
>> each entry is of type elem::Complex<int> (or perhaps instead 'int'
>> modulo a prime).
>> 2) Greatly improved random number generation. I find myself wanting to
>> implement a fast parallel scheme for generating/applying a Haar matrix
>> as part of an eigensolver scheme, but Elemental still hasn't decided on
>> how it wants to draw from normal distributions (a while back it did so
>> via Box-Mueller, which I now realize was a bad idea [2]), and I find it
>> silly to be manually implementing this when the new standard [1,p.934]
>> almost certainly provides something better. Furthermore, this avoids the
>> mess of Windows platforms not providing a C-style double-precision
>> uniform random-number generator (e.g., drand48()).
>> 3) 'extern' templates [3] can likely be used to accelerate Elemental's
>> build system by avoiding the need to redundantly instantiate all of
>> Elemental's template classes within every translation unit. I care about
>> build system times, and while the current approach is a nice compromise
>> between the header-only and traditional source-file approaches, there is
>> obvious value in further decreasing build times.
>> 3) 'auto' [4] and move semantics [5] can both be used to generally
>> simplify Elemental's syntax. For example, current code such as:
>>      elem::DistMatrix<double> C;
>>      elem::Gemm( NORMAL, NORMAL, 1., A, B, C );
>> could be replaced with
>>      auto C = elem::Gemm( NORMAL, NORMAL, 1., A, B );
>> And, while we're on the subject, it would be simple to take this one
>> step further and add a few more obvious overloads for the usual cases
>> (i.e., NORMAL as the orientation option and 1 as the scalar coefficient)
>> to simply write
>>      auto C = elem::Gemm( A, B );
>> I think that these sorts of syntactic simplifications make a large
>> difference over time. And this does not require any expression-template
>> hackery.
>> 4) 'lambda' functions would be very convenient replacements for the
>> current functor approaches taken by routines such as
>> elem::RealHermitianFunction [6] and elem::Egorov [7].
>> 5) The addition of '_Pragma' [1,p.30] would allow macros to contain
>> #pragma statements. This would allow all of the many cases such as [8]
>> to be simplified from three lines of preprocessor directives to one
>> concise macro, e.g., PARALLEL_FOR.
>> 6) 'long long int' is guaranteed [9] by C++11, but not C++03, to be at
>> least 64-bit, which would be useful to set as Elemental's datatype for
>> storing global matrix dimensions. A regular 32-bit 'int' should stay the
>> default for local matrix dimensions, at least until MPI makes the switch
>> itself (but I don't want to get into this tangential point about MPI). I
>> know that we've extensively discussed this issue in the past, but I like
>> having 64-bit integers as a built-in datatype.
>> Is any of these particular items sufficient to justify the migration to
>> C++11? Probably not. But, in combination, I think that they are. The
>> migration will likely start in the near future.
>> Jack
>> [1] http://www.open-std.org/jtc1/sc22/wg21/docs/papers/2012/n3337.pdf
>> [2] http://stackoverflow.com/a/3265174/1119818
>> [3] https://en.wikipedia.org/wiki/C++11#Extern_template
>> [4] https://en.wikipedia.org/wiki/C++11#Type_inference
>> [5] https://en.wikipedia.org/wiki/C++11#Rvalue_references_and_move_constructors
>> [6] https://github.com/elemental/Elemental/blob/master/include/elemental/lapack-like/HermitianFunction.hpp
>> [7] https://github.com/elemental/Elemental/blob/master/include/elemental/matrices/Egorov.hpp
>> [8] https://github.com/elemental/Elemental/blob/master/src/core/dist_matrix/mc_mr.cpp#L485
>> [9] https://en.wikipedia.org/wiki/C++11#Type_long_long_int
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
