[petsc-dev] C++11, compatibility versus simplicity
Karl Rupp rupp at mcs.anl.gov
Fri Oct 4 03:41:24 CDT 2013
Hey,
> So should we (a) turn it on by default for all compilers that support it
> and give an option to use an earlier standard, (b) turn it on
> automatically as a side-effect of enabling a package that requires it,
> or (c) require that the user configure --with-cxx-dialect=C++11?
I agree with Matt here and opt for (c). Although GCC 4.8.1 finally
claims to have full support for C++11, it will take years from now until
this is broadly available on all major platforms including enterprise
systems. For example, the current CentOS ships with GCC 4.4.7, and this
is by far not the oldest OS installed out there.
With (a) we might introduce build failures for standard installs for no
good reason, i.e. try C++11 even if not necessary, and require users to
manually change it back if something goes wrong. I consider (b) to be a
reasonable option to go as well for many cases right now, but it has
some long-term flaws: Imagine similar ABI incompatibilities exist in
C++14 and C++17, then persuing (b) will result in a hodgepodge of silent
hops between different versions if a user 'accidentally' enables a
package which will change the compiler version.
Although I do have some opinions on C++11 and on whether why or why not
one would want to drop support for a plain C++03 build, I'll refrain
from an extensive discussion here because we will sooner or later have
to deal with packages only supporting C++11 anyway. Giving early
feedback to package authors about build breakages with C++11 even though
the package works fine with C++03 is the best we can do in order to make
things as painless as possible.
Best regards,
Karli
