[petsc-dev] [petsc-maint] Installation problem due to Lapack
    Barry Smith
    bsmith at mcs.anl.gov
    Thu Oct  3 11:17:13 CDT 2013
  Why is this not being tested at ./configure time?    If the --with-shared-libraries is on, then each package tested needs to also test that the package can be used with shared libraries.  Easy enough to test. Matt could you please add this?
   Thanks
   Barry
On Oct 3, 2013, at 10:27 AM, Michel Laurent <laurent.michel at epfl.ch> wrote:
> Hi,
> Here is what I did to install petsc-3.4.2, download today on the web:
> CURR=$PWD
> PETSC="petsc-3.4.2"
> LAPACK="lapack-3.4.2"
> CMAKE="cmake-2.8.11.2"
> tar xvfz $PETSC.tar.gz
> tar xvfz $LAPACK.tar.gz
> tar xvfz $CMAKE.tar.gz
> sudo apt-get install gfortran
> cd $CMAKE
> ./configure --prefix=/home/lmichel/cfsSIA3D/cmake
> make
> make install
> cd ..
> rm -Rf $CMAKE
> CMAKE=$CMAKE/bin/cmake
> cd $LAPACK
> mkdir build
> cd build
> $CMAKE -D CMAKE_BUILD_TYPE:STRING="Release" -D CMAKE_INSTALL_PREFIX:STRING="$CURR/lapack" ..
> make
> make install
> cd ..
> cd ..
> rm -Rf $LAPACK
> cd $PETSC
> export PETSC_DIR=$PWD
> ./configure --prefix=$CURR/petsc --PETSC_ARCH=cxx_gnu --with-clanguage=C++ --with-debugging=0 --with-mpi=0 --with-blas-lib=$CURR/lapack/lib/libblas.a --with-lapack-lib=$CURR/lapack/lib/liblapack.a
> make PETSC_DIR=$CURR/$PETSC PETSC_ARCH=cxx_gnu all
> Now, the thing is I get following error messages:
> making shared libraries in /home/lmichel/cfsSIA3D/petsc-3.4.2/cxx_gnu/lib
> building libpetsc.so
> /usr/bin/ld: /home/lmichel/cfsSIA3D/lapack/lib/liblapack.a(dgeev.f.o): relocation R_X86_64_32 against `.rodata' can not be used when making a shared object; recompile with -fPIC
> /home/lmichel/cfsSIA3D/lapack/lib/liblapack.a: could not read symbols: Bad value
> collect2: error: ld returned 1 exit status
> make[2]: [shared_linux] Error 1 (ignored)
> **************************ERROR************************************
>   Error during compile, check cxx_gnu/conf/make.log
>   Send it and cxx_gnu/conf/configure.log to petsc-maint at mcs.anl.gov
> make: *** [all] Error 1
> and I can figure out what is wrong. Can you help me?
> Cheers,
> LM
> Laurent Michel
> Docteur ès Sciences
> EPFL SB IACS ASN
> MA C2 644
> +41 21 693 42 46
> +41 77 428 83 94
> http://mathicse.epfl.ch/~lmichel
> <make.log><configure.log>
