[petsc-dev] Invalid read in PetscSubcommSetTypeGeneral
    Stefano Zampini
    s.zampini at cineca.it
    Wed Oct  2 10:40:33 CDT 2013
Is it the right solution?
diff --git a/src/sys/objects/subcomm.c b/src/sys/objects/subcomm.c
index 752550d..17ef49b 100644
--- a/src/sys/objects/subcomm.c
+++ b/src/sys/objects/subcomm.c
@@ -186,7 +186,7 @@ PetscErrorCode PetscSubcommSetTypeGeneral(PetscSubcomm
psubcomm,PetscMPIInt colo
   ierr =
MPI_Allgather(sendbuf,2,MPI_INT,recvbuf,2,MPI_INT,comm);CHKERRQ(ierr);
   ierr = PetscMalloc(nsubcomm*sizeof(PetscMPIInt),&subsize);CHKERRQ(ierr);
-  for (i=0; i<2*size; i++) {
+  for (i=0; i<2*size; i+=2) {
     subsize[recvbuf[i]] = recvbuf[i+1];
   ierr = PetscFree(recvbuf);CHKERRQ(ierr);
2013/10/2 Stefano Zampini <s.zampini at cineca.it>
> Hong,
> currently in master there's an error in PetscSubcommSetTypeGeneral, namely
> in the loop starting at line 188
> for (i=0; i<2*size; i++) {    subsize[recvbuf[i]] = recvbuf[i+1];}
> recvbuf is allocated at line 178 as 2*size*sizeof(PetscMPIInt), and the
> loop tries to read at location 2*size
> Could you please fix it?
> Ph. D. Stefano Zampini
> CINECA
> SuperComputing Applications and Innovations Department - SCAI
> Via dei Tizii, 6 00185 Roma - ITALY
> Email: s.zampini at cineca.it
> SkypeID: stefano.zampini
> GoogleTalk: stefano.zampini at gmail.com
> Tel: +39 06.44486.707
CINECA
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131002/fccc6d83/attachment.html>
